Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 01:12 PM
460/5's Avatar
460/5 460/5 is online now
460/5 is starting off with a positive reputation.
Question IDI Power?
hey guys. im not new to FTE, but i AM new to the IDI section. im looking at buying one that was swapped into a 77 highboy, and im wondering what kinda power i can expect from these motors? and fuel mileage? it has a 5 speed mated to it.
__________________
Trey, aka Stretch, aka Slim, aka Shorty, aka Seven-Footer, aka Daddy Longlegs.
'91 F250 red long box super cab w/ 460, 5 speed, 4x4.
'76 F100 tan custom single cab short bed w/ 360, 4 speed, NP205 4x4.
'78 F150 white single cab long bed w/ 400, C6, NP205 4x4.
Imagine what I could do if I had all my brain cells.
  #2 (permalink)
Old 10-27-2009, 01:16 PM
joe f350's Avatar
joe f350 joe f350 is offline
joe f350 is gaining momentum as a positive member of FTE.
175 hp 316 tourge is it a 6.9 or 7.3 turbo can riase the number 250hp 500 toure
__________________
85 ford f350 lifted 11 inch 37 6.9 t19 my freinds call it the panzer
  #3 (permalink)
Old 10-27-2009, 01:20 PM
460/5's Avatar
it is 1991 7.3L. how hard or easy is it to put a turbo on em? and what kinda mileage can i expect with out one vs. with one?
__________________
  #4 (permalink)
Old 10-27-2009, 01:28 PM
joe f350's Avatar
turbos can give u about 2 mpg more ur high boy is a f150 right the turb is bolt on there are no cpus on these trucks
__________________
  #5 (permalink)
Old 10-27-2009, 02:59 PM
460/5's Avatar
highboy is an f250. is the 460 gas radiator big enough to cool the 7.3?
__________________
  #6 (permalink)
Old 10-27-2009, 05:15 PM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
Quote:
not from what i have read but have not actaully tried it.
__________________
91 F-250 7.3 N/A ZF-5 2wd, 4" ram air, Isspro gauges, IP turned up, 265/75/16 A/Ts, 15% tint, carter p4594 ele pump, 55w back up lights, class V hitch, 4" exhaust w/14" magnaflow diesel muffler, steering stabilizer (DD/hauler)
88 F-250 460 c6 4x4 Lifted on 36" TSL super swampers, stacks, MSD 6al, holley red, warn hubs (Mud truck)
  #7 (permalink)
Old 10-27-2009, 06:48 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
That depends on what you intend to do with the truck.
Heavy hauling or towing in the summer, probably not going to do the job.
Just driving around, probably will be enough.
Diesel radiators are four core, brass and big.
The diesel radiator support is 6" taller than the gasser radiator support.
Mileage depends on where you live and how you drive more than what equipment you have.
Mountains, nothing flat and drive fast, 12 MPG.
Flat country, low elevation, drive reasonable, 15 to 20 MPG.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 10-27-2009, 07:02 PM
morimoto_87's Avatar
morimoto_87 morimoto_87 is offline
1991 Ford F-250
morimoto_87 is starting off with a positive reputation.
My 1991 F250's 7.3 Gets 10-13 here in Omaha, Mainly because it's intown driving and theres not a piece of flat fricken road in this city to drive on so I'll vouch for the bad intown hilly mileage. When i go home to Minnesota it gets about 17-20 so theres a big difference in mileage depending on your terrain and how you drive this engine.
__________________
1991 F250 with a bignasty 7.3 IDI n E4OD, 3:55's, 285/75/16 UNIROYAL RADIALS
  #9 (permalink)
Old 10-27-2009, 07:11 PM
1986 Ford F-250
The elevation in Omaha is not helping you either.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #10 (permalink)
Old 10-27-2009, 07:31 PM
1991 Ford F-250
Really, i didn't realize the elevation here was so much different i guess...whats the best way to tune the engine to take the elevation here a little better? Any ideas to help me out?
__________________
  #11 (permalink)
Old 10-27-2009, 07:58 PM
460/5's Avatar
ok. so it has a 5 speed. lets say im cruisin 70 around 2500 feet on open, slightly hilly roads, after adding a turbo, and running 33 to 35 inch tires with 4.10 gears?
__________________
  #12 (permalink)
Old 10-27-2009, 08:08 PM
1991 Ford F-250
i would guess between 12 and 16 maybe...
__________________
  #13 (permalink)
Old 10-27-2009, 08:44 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn is starting off with a positive reputation.
Your not gonna get great fuel mileage with 4.10 gears not going 70 anyways. I get around 14mph with my 7.3 non-turbo 5 speed 4.10 gears, that's only going 60 mph, I rarely go over that speed.
__________________
Driving a Diesel adds a whole new meaning to smoking the competitor!
1990 Ford F250 4x4 5 speed 4.10 gears N/A 7.3 Diesel 568,000km/375,000miles, still on the orignal clutch!
1987 Ford E350 C6 Trans 3.55 gears N/A 6.9 Diesel Motorhome 26ft. weighin' 11,000 pounds and it's slow goin' up hills lol.
  #14 (permalink)
Old 10-27-2009, 09:01 PM
1986 Ford F-250
33" tires will have you running 70 MPH at 2200 RPM with 4.10 gears and a ZF 5 tranny.
35" tires would drop the RPM to 2100 at 70 MPH.
Don't know why, but I thought Omaha was higher than 1100 feet.
I always thought it was about the same elevation as Ogallala at 3500 feet.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #15 (permalink)
Old 10-27-2009, 09:49 PM
1991 Ford F-250
That sounds a little better... Those 33's are tough on mileage.
Ya, omaha is between 1000 and 1300 feet.. Ogalalla is going into the dunes...going towards the rockys...
__________________
Tags
idi , power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
