10.25 rear oil change - Ford Truck Enthusiasts Forums
Old 10-27-2009, 12:53 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
<hr style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);" size="1"> <!-- / icon and title --> <!-- message --> <!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --> <!-- END TEMPLATE: ad_showthread_firstpost_start --> The rear on my truck has been leaking oil around the rear diff cover for awhile, so I want to pull the cover off, replace the gasket, and put in new oil.
So, I have a couple questions, namely:
1. What weight oil, and can I go synthetic?
2. How much oil does it take?
3. What friction modifier do I need, and how much? (truck had a trak-lok)
BTW on these ones is it better to use silicone on the diff cover, or a regular paper gasket?
Old 10-27-2009, 01:07 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Your axle came with synthetic......
Approximate Lubricant Capacity (In-Vehicle Repair)(a) (b)
Vehicle F-250, F-350 Regular & Chassis CAB, F-250/350 H.D.
Axle 10.25-Inch Ring Gear
U.S. Pints 6.5(c) (d)
Imperial Pints 5.4
Liters 3.0
(a) - Ford design conventional axles use Rear Axle Lubricant XY-90-QL or -KL (ESP-M2C154-A) or equivalent.
(b) - Service refill capacities are determined by filling the axle with the specified lubricant to the bottom of the filler hole with the vehicle in running position.
(c) - Plus 8 oz. (U.S. measure) additive friction modifier, C8AZ-19B546-A (EST-M2C118-A) or equivalent for limited-slip applications.
(d) - Rear axle lube quantities must be replaced every 100,000 miles (160 000 km) or if the axle has been submerged in water. Otherwise, the lube should not be checked or changed unless a leak is suspected or repair required.
Note: 6.5 pints of lubricant is the fill specification when the axle is installed in the vehicle. If the axle is out of the vehicle, fill with 7.5 pints of specified lubricant.
Old 10-27-2009, 01:45 PM
ghunt's Avatar
What the hell is XY-90-QL? Any idea what weight that is?
Old 10-27-2009, 05:27 PM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
i searched here and when i did mine i used syntheic blend 80-90wt also if you have limited slip add the friction modifier. i think mine was 3 qts maybe a little more
M50D Top Cover Bovaloe 1987 - 1996 F150 & Larger F-Series Trucks 23 03-19-2013 01:51 PM
Rear Main Seal is Leaking OutlawNomad New Jersey Chapter 7 04-07-2010 09:07 AM
Torque spec Dana 80 GTOBRIAN 1999 to 2016 Super Duty 0 12-08-2009 08:21 PM
2001 Ford F450 Crew cab, 7.3 Diesel nepsis 1999 - 2003 7.3L Power Stroke Diesel 7 12-04-2009 04:40 AM
my 97 f350 reverse set up for the guys here in Wahington crash1 Washington Chapter 7 02-25-2009 08:17 PM
Tags
1025, 1100, additive, axle, change, diff, end, f250, ford, gear, lubricant, oil, rear, sterling, vstar, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
