Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 12:30 PM
itsjustdan26 itsjustdan26 is offline
itsjustdan26 is starting off with a positive reputation.
Factory Stereo Question
Hey Folks,
Just wondering if the factory stereo has pre-amps in the back for a couple of subs and amp. If not, then what kinda stereo is a better way to go with? I have an 01 F250 EC. Thank you for your input!
  #2 (permalink)
Old 10-27-2009, 12:54 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is gaining momentum as a positive member of FTE. riverrat41 is gaining momentum as a positive member of FTE.
Don't know.Here's a bump
__________________
Barry.....FISH HUNTER!
Tony Wildman Chip , 4''Exhaust, 6637w/Pete's Cover, Crossover, AIH Delete, Foil Delete, WW, Ped Gutted, Tugger Kit, Isspro Gauges, CCV, Recon smoke cab lights, Camo seat covers, Replacement Bumpers, Hutch/Harpoon ,Cold A/C Mod, True Cool
  #3 (permalink)
Old 10-27-2009, 01:33 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3 STROKIN'IT7.3 is offline
STROKIN'IT7.3 has a very good reputation on FTE. STROKIN'IT7.3 has a very good reputation on FTE. STROKIN'IT7.3 has a very good reputation on FTE.
No preamp but i believe there is a signal wire (blue w/white tracer) could be wrong here but I know there isnt preamp rca's. I have a simple single DIN Alpine unit: Alpine Electronics of America, Inc. - CDA-9886
Second one I've owned and absolutely love it. Coupled with 2 10" rockford p2's in a box under the rear seat (extended cab)
__________________
WILL PAA #30
2001 F250 XLT Auto EC LB 4x4
THE DP Tuner, a few other goodies
1931 Model A 78-B "Wide Bed"
Join the Virginia Chapter!! http://www.ford-trucks.com/forums/forum147/
  #4 (permalink)
Old 10-27-2009, 02:17 PM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
No pre-amp outs at all. IIRC you can buy a converter that you can splice into the wires to convert to RCAs. Not the best quality sound, but it's cheaper than a new head unit.
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #5 (permalink)
Old 10-27-2009, 04:23 PM
westpsd westpsd is offline
westpsd is starting off with a positive reputation.
You can purchase a match maker at walmart for $15 that hooks to your speaker wires. Hook it to the rear speakers so you can fade the bass by changing the fader in the radio. It will work fine for subs. It takes the high level outputs for the speaker and changes it to low level (RCA) for the amp. Be advised, some amps today already have high level inputs in which case you wouldn't even need the match maker.
Jim
__________________
WestPSD
Early '99 F250 Lariat SC SB 4x4 7.3, 305-70-16's, BRV+,
DP Tuner 6 Pos, 4" exhaust, K&N FIPK, Gages, Sonnax kit, 3 disc-billet converter, X-Springs, Warn premium hubs, True-Cool, 3.73's, Line-X, goose neck, 5er, AutoEnginuity
  #6 (permalink)
Old 10-27-2009, 04:35 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
I just tapped the rear speakers for my amp -- it already had high level inputs. Works like a champ! I used those plastic clip splice things, BTW. Easy-cheesy.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
