18984 F250 Wheel interchange with other brands ( Chevrolet, GMC, Dodge ) - Ford Truck Enthusiasts Forums
Old 10-27-2009, 10:09 AM
petepetersen petepetersen is offline
petepetersen is starting off with a positive reputation.
I have seen some posts on this subject but am still confused.. I am looking for some wheels with tires mounted on them and want to know what fits my 1994 F250 . Is there a chart or list somewhere ( web link ?) - Thanks
Old 10-27-2009, 01:02 PM
atccracing atccracing is offline
atccracing is starting off with a positive reputation.
You have an 8 lug right? I did some research on this, but don't remember all the numbers off the top of my head. I do remember the Dodge trucks (it was an older generation) used a metric 8 lug, that when converted to standard was the same as the ford 8 lug. Go on a few web sites that specialize in rims, and one of them is bound to have the popular lug patterns. Then you just compare a few and see what you get. That's how I found the Dodge.
Old 10-27-2009, 01:25 PM
Yes the my 1994 F250 IDI current has the stock 8 lug 16 inch wheels ( with 235/85/16 E tires) .
Old 10-27-2009, 03:28 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
80-97 f250 and 350 use a 8 on 6.5 pattern
80-current dodge use a 8 0n 6.5 pattern
80-current chevy use a 8 on 6.5 pattern
-Now FORD fell off their rocker in 98 and went to a 8 on 170mm
-chevy stock wheels have a smaller center hub and will not fit a ford without machining
Dodge wheels will fit as far as i know
As for aftermarket wheel, i believe they are all the same for 8 on 6.5 pattern
Old 10-27-2009, 04:14 PM
Diesel_Brad - That helps.. I am not interested in having to machine center hub openings .
Old 10-27-2009, 05:18 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
63-97 Ford F-250/350 use an 8 on 6.5 pattern, and maybe back further
Old 10-27-2009, 05:54 PM
Quote:
Yes but the hub center changed somewhere along the line and would require machining as well
Old 10-28-2009, 10:51 AM
The original split rims that came off of it (my 63 F250 4x) went on a 1978 Ford E250 after I pulled the 460/C6 combo out of it and I took those rims and passed them on to a friend who needed a winter set for his chevy.
Aftermarket Eagle Alloys 1459's are now on my 63, which came off a 87 chevy. If you are looking for stock take-offs, as stated, some chevy rims will need the center machined, if you are going aftermarket, most of them come with the larger hole, I would peruse the ol' craigslist in and around your area, I have bought 2 sets, W/tires on craigslist each set of 4 for 2 bills.
Which Turbo Wheel ilike2fixit 1999 to 2016 Super Duty 2 03-06-2015 10:27 AM
Which Turbo Wheel ilike2fixit 1999 - 2003 7.3L Power Stroke Diesel 6 03-04-2015 09:12 PM
Will 2009 wheels fit my 2000 superduty? SUPERDUTYOKIE Brakes, Steering, Suspension, Tires, & Wheels 6 01-18-2014 08:21 AM
Wheel Backspacing? j7angus 1973 - 1979 F-100 & Larger F-Series Trucks 8 06-13-2011 12:54 PM
16x10 wheels on a 78 f250 toddn78 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-22-2005 09:31 PM
Tags
1987, 1996, 2002, chart, chevrolet, chevy, dodge, f250, fit, ford, interchange, lug, pattern, rims, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
