Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 09:52 AM
gearloose1 gearloose1 is offline
gearloose1 is starting off with a positive reputation.
EGR? Turbo? What is this? P0405 P0404 code
I have a 2005 6.0 PSD in a E-350.
200 miles ago, the Check Engine Light came on, and I got a P0404 and 0405 code, which I just cleared as everything is fine.
Today, driving fully warmed up (10 miles after start), suddenly, the engine lost power (as if the turbo was not boosting), and the Check Engine Light came on again.
I drove it to a parking lot (with noticeable loss of power) even though once I stopped, it seem to have reved fine in neutral.
Stopped the engine, restarted it after 20 minutes of shopping....
Check engine light is still on....
Started engine, and the bogging / loss of power was GONE!
Read the codes at home as P0404 and P0405 (2 instances of each).
Here is my hypothesis:
a) did some carbon get stuck in the EGR valve or the turbocharger or both?
b) did it fix itself (carbon got dislodged from whatever it is jamming)?
What should I do next?
Thanks
  #2 (permalink)
Old 10-27-2009, 02:25 PM
texans's Avatar
texans texans is online now
texans is gaining momentum as a positive member of FTE.
Those are egr codes sonds like you have a problem with the egr valve. Migh want to pull it and clean it up. There is a good write up on it in the tech folder
__________________
2006 F-250 Lariat C.C, 18" rockstars w/285/65 nittos, SCT w/custom tunes, Banks Ram-Air Intake, 5" MRBP exhaust w/o kitty, 2.5" levealing kit, readylift air bags, fumoto drain valve, Viper alarm with remote start, 2-10" MTX Subs, drilled and sloted front rotors, ARP studs sitting in shop waiting on other parts.
come Join the Texas Chapter!!
Scotty
  #3 (permalink)
Old 10-27-2009, 08:25 PM
Texan,
As usual, thanks for your prompt response.
  #4 (permalink)
Old 10-27-2009, 08:32 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
most likly carbon hung the valve pull valve and look in side intake. if its pack you have a few options.
1)new intake.
2) remove yours and send it out and have it hot tanked.
also is you have to take it off look inside the egr cooler if its packed then that will need to be replaced or deleted. if yoy do so it is highly recomened to reman the oil cooler
  #5 (permalink)
Old 10-27-2009, 09:59 PM
texans's Avatar
No problem. If you have anymore questions don't hesitate to ask
__________________
Scotty
Tags
60 , 60l , code , description , diesel , e350 , egr , f150 , f350 , ford , location , p0404 , p0405 , powerstroke , psd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
