I had the the same problem with my windows after I replaced the glass and installed new anti-rattle trim. What I ended up doing was disconnecting the lower track from the rollers so the window would drop down into the door,removed the lower felts and enlarged the window opening in the door.In my case I think the truck had been without the window trim for too many years and the repeated door slamming caused the window opening to close up. If you have a new paint job use care enlarging the opening so you don't chip the paint. You can use a wooden wedge or something similar to spread the window opening.
