Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 09:30 AM
bren7176's Avatar
bren7176 bren7176 is offline
bren7176 is starting off with a positive reputation.
Heater
Has anyone ever put a intake heater on their power stroke? I know Dodge has the grid heater is there a mod to add one to the ford I would think this would be a good thing ..
  #2 (permalink)
Old 10-27-2009, 09:33 AM
mueckster's Avatar
mueckster mueckster is offline
Redneck Wrencher
mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold
'99.5 and up already have an Air Intake Heater in the manifold (spider). Most remove it because of its air flow restriction. It is a wire coil that heats up the air to reduce smoke "after" start up and only engages when the temps are low enough.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6, AFE II w/ Pete's Cover, Garrett GTP38R w/ 1.15, 6.0 IC, Casserly SS 160cc 100% over, Stealth HPOP, Autometer Phantom gauges, DIY HD 4R100, 4" MBRP, Procomp lift pump, CCK, TruCool, billet 710 cap, Truetrac rear
PAA Member #62
  #3 (permalink)
Old 10-27-2009, 09:34 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of
You have one on the spider. Take your passenger side boot off and look inside. It looks like a curley cue. lol
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-VB, DP-TUNER LIVE- stock, HI. 40t, 60t, decel, 80t, 80e, 140s, OBA, 203*, billet housing, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #4 (permalink)
Old 10-27-2009, 09:39 AM
mueckster's Avatar
Redneck Wrencher
If you have an early '99, you won't have one. Your profile didn't say which truck you have. It just said 99. Also, you will have an additional relay for the AIH in front of the glow plug relay on the passenger side head.
__________________
-Roland-
PAA Member #62
  #5 (permalink)
Old 10-27-2009, 10:08 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Since we have GPs, we don't need a grid heater. The AIH is ONLY for white smoke control when idling cold. It does NOTHING for warm-ups. The EBPV will "help", but a lot of us gut that too. I no longer have an AIH or EBPV and don't miss them at all.
__________________
  #6 (permalink)
Old 10-27-2009, 10:13 AM
brandon_oma#692's Avatar
brandon_oma#692 brandon_oma#692 is offline
brandon_oma#692 is starting off with a positive reputation.
Thats fine in texas I was scraping ice off my windshield this morning time for me to move
__________________
1999.5 F_250 sd 143,000 Riffraff 6637 and CCV Excursion heated power leather seats.
  #7 (permalink)
Old 10-27-2009, 11:34 AM
bren7176's Avatar
heater
What I meant is there a aftermarket mod to put a grid heater on the 7.3l to use that instead of the glow plugs .
  #8 (permalink)
Old 10-27-2009, 11:37 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
No, there is no "mod" like that.
Why would you want to do that?
Do your glow plugs not work? There are fixes for that.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #9 (permalink)
Old 10-27-2009, 02:32 PM
aklim's Avatar
aklim aklim is offline
aklim has a good reputation on FTE. aklim has a good reputation on FTE.
Quote:
Why would you want to put a restriction in your intake system?
__________________
01 Excursion. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BDP Stage II AC injectors. Bilstein Shocks with U code front and A code Rear. 203* thermostat and billet housing
  #10 (permalink)
Old 10-27-2009, 04:39 PM
Izzy351's Avatar
Getting Faster...
Quote:
Yeah, it *is* "fine" here. But it's also "fine" in Alaska and Northern Canada. There are several members here in very cold climates with nothing but glow plugs. When it's VERY cold, you might want to wait a little longer than the WTS light. And yes, they stay on longer than WTS light. That just tells you a minimum time to wait. You can wait longer. You can also put your own indicator so you know when they're on. They do stay on after starting, too. I just watch my battery voltage -- I can see when they shut off when the voltage jumps up.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
