Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 08:30 AM
rideracelivemx7 rideracelivemx7 is online now
1995 Ford F-250
rideracelivemx7 is starting off with a positive reputation.
good injector seals?
is there a preferred brand? i know the seals on ebay are about 100$ that's all i know about where to get them, need to do them soon. its getting smokey in the mornings! and motor craft for the glow plugs correct?
__________________
red 7.3 powerstroke diesel-6637-10k-6 POS chip big name tunes-HPX line-3" Downpipe--> 6" Aussie stacks! 3:55s auto-122k miles-Rotella Synthetic, ebpv butterfly removed
  #2 (permalink)
Old 10-27-2009, 11:07 AM
yeldarb82 yeldarb82 is offline
yeldarb82 is starting off with a positive reputation.
or beru glowplugs
  #3 (permalink)
Old 10-27-2009, 11:22 AM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
Motorcrafts should be the BERU.
My ZD-11 Motorcrafts were BERU.
Thats what I would get, they were really nice. It's what I pulled out also. No swelling.
I forgot what ones jim uses, they were pretty nice quality o-rings.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit, Stancore GPR.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
Quote:
Originally Posted by Action4478
the columns aren't made out of marshmallows...Just wiggle it ....
  #4 (permalink)
Old 10-27-2009, 11:57 AM
1995 Ford F-250
Yeah I'm afraid to see what happens when I go to try and pull the GPs. I don't know the previous maintenance on the truck, its super clean so I'm guessing it was loved very much but but for all I know, they could be the stock glow plugs! When I do a full cycle on them the truck takes longer to crank... versus this morning it was 30 degrees this morning and didn't cycle them and the truck started like it was a nice warm sunny day??
__________________
  #5 (permalink)
Old 10-27-2009, 11:04 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
I have been using these for a couple of years without any problems.
Rog
WAP, Inc. - Glow Plugs for Diesel Engines, Off Highway Equipment and Automotive Applications
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #6 (permalink)
Old 10-28-2009, 12:31 AM
pjwoolw's Avatar
pjwoolw pjwoolw is online now
pjwoolw is gaining momentum as a positive member of FTE.
I've considered those too Rog. Good to see a positive review.
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #7 (permalink)
Old 10-28-2009, 12:46 AM
kawa's Avatar
Just to add to it Pete. Approximately one (1) year ago I had the valve covers off and decided to pull the glow plugs just for grins and giggles to see how they were holding up. There was no swelling and virtually carbon free.
Rog
__________________
  #8 (permalink)
Old 10-28-2009, 07:02 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
FTE Sponsor
DZL JIM is gaining momentum as a positive member of FTE.
Get your o-rings from this guy on eBay: Angelo.
They are oem Allaint Power, you can't get any better.
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
StackCovers.com
DieselJunk.com
DZLJIM.com
  #9 (permalink)
Old 10-28-2009, 08:57 AM
Talyn's Avatar
1994 Ford F-250
The BERU's I pulled were pretty clean and had no swelling. Came out with ease.
Allaint power, I sold some of their stuff before when I helped my mom.
She sold seals, orings and all taht fancy stuff for hydrollics and everything associated with them and air and gas cylinders.
__________________
  #10 (permalink)
Old 10-28-2009, 02:52 PM
1995 Ford F-250
awsome thanks Jim, i was awaiting on your info, i was actually skimming your site and did not see a just oring kit, but i will try this guy. Thanks for the imput guys!
__________________
  #11 (permalink)
Old 10-29-2009, 05:09 AM
Iallwork Iallwork is offline
Iallwork is starting off with a positive reputation.
awesome guys!
hey, I have a 97 PSD. I've been thinking about injectors. Way back when ever I put in a Banks Stinger kit. It had a turbo housing, chip , and exhuast(down pipe). 240,000 on it now. I just want a some more power . I'm thinking about stage one injectors. I pull often. Ican put them in and maybe build them (minus machine work). Is this a bad idea because of the miles?
  #12 (permalink)
Old 10-29-2009, 09:24 AM
1995 Ford F-250
not so much a bad idea, just be able to replace or rebuild the tranny if and when the time comes with the new sticks, really watch your EGTS if you do sticks with the smaller housing, yeah it spools faster but it can yeild some high egts with sticks in there. if you dont mash it with a trailer on all the time you should be fine
__________________
Tags
1986 , 1997 , 69 , code , deisel , diesel , direct , f250 , ford , injection , injector , injectors , powerstroke , problem , seal , seals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
