Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 03:26 AM
TheKirbyMan TheKirbyMan is offline
TheKirbyMan is starting off with a positive reputation.
Synthetic Auto Trans Fluid...Pros and Cons?
I have a 1981 F-150 with a 302, C6 transmission, and 9" axle. The transmission has had a pan gasket leak for years, and at some point in the near future I hope to fix this leak, as well as change the filter and fluid.
So I'm curious, what are the pros and cons of using a synthetic transmission fluid?
Also, will the transmission benefit from it? The odometer reads a bit over 60K; I'm guessing it means 160K, since the truck runs quite well for its age (carburetor issues aside). The transmission has been unintentionally run low on fluid a number of times, but I always brought it back up to level as soon as possible.
Any help is appreciated. Thanks!
__________________
1981 F-150 Custom 302/C6 9"
FORD: The Best Never Rest!
  #2 (permalink)
Old 10-27-2009, 10:28 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
Most all the newer trannies are going to synthetic or synthetic blends from the factory. It's pretty good stuff. That being said, I would not put synthetic in your tranny unless the manufacturer of the oil says it's backward compatible. The tranny is designed around the fluid that is recommended for it. That's why there are so many types of tranny fluid.
So if you find a synthetic fluid that says it replaces dexron/mercon that was originally in your tranny, I would try it. Even when you buy the regular fluid, you have to read the bottle. They have a dexron/mercon I, II, III, etc, but if you read the bottle they say the newest fluid is compatible with the older types usually. That's what you need to worry about whenever changing the tranny fluid.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 10-27-2009, 02:16 PM
Of course. Over the past several years, I've become rather familiar with the different types, since I've had to buy the right kind almost on a weekly basis sometimes. lol
I'll do some looking around and see what my options are. Thanks for the info!
__________________
Tags
1986 , amounts , automatic , c6 , change , cons , f150 , fluid , ford , leaks , pros , tranny , trans , transmission , truck , types
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
