You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
man i cant find a book to help me any weres for this truck of mine its a 1970 ford f100-250 not sure its 4x4 with a 300 straight 6 but i dont know were the orange wire go"s for the fuel gage in my cluster i know its like beating a dead dog but can some plz help me and hell me were this thing go"s my dad told me it go"s up to the cluster that cant be right were in the hell dose the wire go if you now or have a wire digram plz help a bro out lol
Well here it is, the orange gas ga wire looks like it's wire doubles back in the #15 tab on the connector plug that goes into the backside of the instrument gauge panel. 1971 had a flex printed circuit strip on the back side where as earlier had wires going to the gauges itself..Remove plug hook an ohm meter from it to where it connects at sending unit if it shows zip it open some where in between..with key off that is.. my 2cents
orich
__________________
1971 F250 4x4 Nv4500-5spd O/D 417cid owned since
1978..Ha who cares what you don't have any more.
Vietnam tour of duty 68-69 15 mo.
Driver of the Iron Butterfly Gun truck http://www.youtube.com/watch?v=5H7U71KZEJw
I can't figure this out either. I put a brand new sending unit in, so its not the sending unit. The gauge was working at one point but I had no lights at all when I bought the truck and took it to a local shop. They were about to get all my lights working, but the fuel gauge hasnt worked since. Not sure what it could be. I have a tester and I tested the orange wire going to the sending unit and I have nothing. Could this be a fuse? I looked on the woring diagram, but it shows the orange wire going from the sending unit to the "Printed circuit circuit connector" What ever that is. I don't see it going to the back of the cluster anywhere.
the orange wire should be going to the plug that plugs into the back side of the dash, I think it's #15 if, I remember right on the plastic plug tab..
The dash lights our the screw in type that make contact with the c-board.
orich
__________________
I inspected the ground wire going to the sending unit and it was barley together. It looks like it was cut and put back together. I touched it and it fell apart. If I repair that wire could that solve my problem?
No ground no worky! think about it, why would it have a ground wire if not needed..
orich
__________________
Let's start over and go back to troubleshooting 101 because I can't seem to make sense of what's been done and what hasn't.
First question: Assuming that you have some gas in the tank, what does the gauge do when you turn on the key? Does it stay on E? Or does it go to F? The answer to this is fundamental to the subsequent troubleshooting path. Further questions to follow after we know the answer to this one.
Remove sender an hook up orange wire. Hook up a jumper ground wire to sender. Ok with the key on Hold sender as it would be in tank, slowly move float arm to about center, gauge should move as you move float arm. If no movement. Remove orange wire and touch to ground still with key on. Now gauge should go to full when grounded. if wires and gauge is good.. orich
__________________
I'm on the road and doing this on my iPhone so if there is any misspelling that I don't catch, please bear with me.
Good. Now we know that there is no current flowing through the circuit. This is NOT a shorted wire; rather, it is an open circuit.
The following simple test will isolate the problem to one of 3 areas: power, gauge or control (tank unit segment).
Test for power on both posts of the fuel gauge. Simply put one test lead to one post of the gauge, the other lead to a good ground. You'll find it may be anywhere between 0 and 12 volts, depending on whether your temp gauge is also operating, because of the voltage regulator unit. Also remember that the "regulator" is really just a betallic switch that turns the 12v on and off, so it generally averages about 12v. Make sure you connect your voltmeter and watch it for several seconds each time to allow for the switching of the regulator. Remember to chech power on both termonals of the gauge.
So here's the next question: Did you find power on both posts, one post, or neither post of the gauge?
(If this is too basic, please say so but I have no idea what your skill level is.)
If you have no voltage on either post, you have a problem with the circuit providing power to the gauge.
If you have voltage on one post but not the other, you have an open circuit in the gauge (bad gauge).
If you have voltage on both posts of the gauge, you have an open circuit between the gauge and the ground after the tank unit.
Okay. I ran a test on the regulator in the back of the cluster. No resistance. I went to a junk yard and took a shot on another cluster. ($30) I tested the regulator on that and got a reading. Switched out the regulators and the gauge works now. A new regulator is 50 bucks through LMC so I guess I didn't do too bad and now I have some extra gauges if I need them.
