Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 09:48 PM
lmnr0026 lmnr0026 is offline
lmnr0026 is starting off with a positive reputation.
Electric Fuel Pump - force system prime?
While the key is on and electric fuel pump going, it runs continuously, albeit slowly. Walbro 7 psi 50 gph 'click'ing every 2-3 seconds. I noticed in another thread someone mentioned leaving an electric pump running for a while to force bleed the injector lines. Anyone else verify this "slow bleed" method? how long does it take?
Thanks,
__________________
1989 7.3L E-350 based Wheelchair Transit bus converted to Recreational Vehicle.
  #2 (permalink)
Old 10-27-2009, 01:10 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Not heard of injector priming with just a fuel pump....... that would require IP pressure of about 1800psi to crack open the pintles.
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 10-27-2009, 05:23 PM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
it bleeds the return lines when i get alot of air in the system i just let the pump run while the GPs are on and then start it and then it will run a minute and stall only sometimes then just a few more seconds maybe 10 on the pump and it starts and runs fine.
__________________
91 F-250 7.3 N/A ZF-5 2wd, 4" ram air, Isspro gauges, IP turned up, 265/75/16 A/Ts, 15% tint, carter p4594 ele pump, 55w back up lights, class V hitch, 4" exhaust w/14" magnaflow diesel muffler, steering stabilizer (DD/hauler)
88 F-250 460 c6 4x4 Lifted on 36" TSL super swampers, stacks, MSD 6al, holley red, warn hubs (Mud truck)
  #4 (permalink)
Old 10-27-2009, 10:07 PM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh is starting off with a positive reputation.
if you install an electric pump bypass or remove the mechanical one unless you like diesel in the crank case
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
  #5 (permalink)
Old 10-28-2009, 12:20 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
Quote:
with a manual fuel pump block off plate that fits the big block chevy.
im learning!
oh yeah,the holy red pump seems to be the preference around here.
i see many doing this due do to making a better system with less starting probs.
but dont forget this is a MPG/HP mod too!!
a manual fuel pump runs off the crank(way old school!!).the holly red's i notice only draw a couple amps!
the hp gain i would bet(for those very used to their trucks) is enough to actually feel.
when you can feel the diff in one mod alone,you know your on your way to freeing up some ponies.
(read some racing equp places where some add's claim "free up "##"HP with a electric fuel pump"-some have proven dyno tests to back up such claims as well)
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #6 (permalink)
Old 10-28-2009, 01:00 AM
Rodpod's Avatar
Rodpod Rodpod is offline
Rodpod is starting off with a positive reputation.
I ran my truck out of diesel completely on the weekend and an electric fuel pump makes it dead easy to get started again. I just bleed from the valve on the fuel filter and that was enough to get started right up. Coughed abit at first but a pretty quick startup.
When i bypassed my Mechanical fuel pump i noticed a huge difference in power , but that was due to the motor actually getting enough fuel for once lol.
  #7 (permalink)
Old 10-29-2009, 10:01 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
I use an EP80S ( 6-7 PSI) in series with the mechanical pump. I only use it to prime the system to relieve the load on the starter. I cut a section out of the metal line going to the filter and insert the electric pump. That way if I have a bad diaphragm in the mechanical pump, I won't fill the crank case with fuel. I only get air into the system which lets me know there's a problem. Actually, the rubber line from the frame to the mechanical pump is long enough that I can slip the connector hose off of the electric pump and bypass the mechanical pump.
Tags
1989 , 2008 , 73 , 97 , adding , continuously , diesel , electric , f150 , f250 , ford , fuel , holley , power , prime , pump , red , runs , stroke , system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
