Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 10-26-2009, 08:14 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
Garage is empty, add now
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Cool Where to Get Real Gasoline in Owasso?.....
Sigh....My shell station on 86th St. has been bought out and the new owners are now using cheap ethanol. Sigh. Where else can i get real gas for my vehicles in Owasso?
Thanks in Advance.
__________________
-Ron
Daily Driver 1978 F150
  #2 (permalink)
Old 10-27-2009, 07:59 AM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
2000 Ford Ranger
MikeB 88 is starting off with a positive reputation.
Ron,
I go to the Sinclair on 96th and 145th. They are still advertising Real Gas.
__________________
Mike B
1969 ForDor Thunderbird
2006 Dodge Charger (wifes car)
2000 Ranger Regular cab
2.5L with A/C backed up by the 5 speed manual, 2WD.
159,000+ on the clock.
  #3 (permalink)
Old 10-27-2009, 09:14 PM
cigarxtc's Avatar
Thx, Mike. I went there a handful of times, until my wife's SUV experienced hard starts on an almost empty tank. I suspect that water or gunk was in the gas and when it got low enough the fuel pump got some in the lines. I ran the wife's truck down to almost E and then filled up at Shell and try to start but it would only crank and crank. After a couple minutes of cranking she finally started running. I have been putting fuel line antifreeze/water remover in each tank since then. It's been about a month or so. Hopefully the water/gunk is out of the tank. I am leary of going back to that Sinclair. Have you tried running any of your vehicles down to E or on fumes while using that Sinclair gas?
__________________
-Ron
  #4 (permalink)
Old 10-28-2009, 07:28 AM
MikeB 88's Avatar
2000 Ford Ranger
Yep!! The Ranger has a 15 gal gas tank and I'm constantly putting in 14 to 14.5 gallons. The Thunderbird usually get filled it's about 1/2 empty. Just because it needs the premium fuel and it's pretty costly to fill up when empty. The Ranger and Thunderbird seemed to run better on their gas than the Shells. But that could just be my imagination though.
__________________
Mike B
  #5 (permalink)
Old 11-03-2009, 08:46 AM
MikeB 88's Avatar
2000 Ford Ranger
Ron,
I was told at work that the Shell station on 76th now has REAL gas. You might want to check them out. I was told that the owners switched stations. Don't know for sure, just passing on what I was told.
__________________
Mike B
  #6 (permalink)
Old 11-04-2009, 07:14 PM
cigarxtc's Avatar
Cool. Thanks, Mike. I'll drive by there on the way home tonight. This QT and Kum&Go Ethanol is definately not lasting as long as real gas.
__________________
-Ron
  #7 (permalink)
Old 11-04-2009, 07:45 PM
MikeB 88's Avatar
2000 Ford Ranger
I stopped there this morning with the Thunderbird and the price matched what REAL GAS would go for. I've been running the real gas from the Sinclair station through it, but have developed a rough idle over the last couple months. Hopefully the Shell gas will clean out some of the gunk in there and bring back my smooth idle.
__________________
Mike B
  #8 (permalink)
Old 01-08-2010, 04:01 PM
Faber's Avatar
Faber Faber is offline
Faber is starting off with a positive reputation.
Quote:
Thanks in Advance.
used to fuel at the same place.
motorcycle, truck, suv
id noticed the switch too and was gonna start looking elsewhere for fuel.
glad you started this thread....thanks.
__________________
"A 64 work truck bought new and kept in the family; from grandpa to his great-grand daughter."
  #9 (permalink)
Old 01-15-2010, 09:06 PM
cigarxtc's Avatar
Yep, the Shell station on 76th Street, next to McD's, sells real gas. It's all i put in both our trucks. I think I'll stay away from that Sinclair station on 96th street, unless they replace their underground tanks. I can drive either truck down to fumes and have no trouble starting with this Shell gas.
__________________
-Ron
  #10 (permalink)
Old 01-16-2010, 09:31 AM
Faber's Avatar
^sweet....thanks man.
ill be heading that way for fuel too....
__________________
  #11 (permalink)
Old 01-16-2010, 11:14 AM
MikeB 88's Avatar
2000 Ford Ranger
I switched from the Sinclair station to the Shell station. The Thunderbird is much happier!! The Ranger likes it to
__________________
Mike B
  #12 (permalink)
Old 02-04-2010, 07:47 AM
MikeB 88's Avatar
2000 Ford Ranger
I'm beginning to think the Shell station on 76th went back to the blended fuel. In this last tank of gas in my Ranger, I'm seeing a good 30 miles difference. The gas gauge is about a needle with below the 1/4 mark and I usually see 315-320 miles at this point. Right now I've driven 295. I'll find out for sure Friday when I stop to fill up.
I've driven no different between the last two fill ups, no unnecessary idling or anything our of the ordinary.
__________________
Mike B
  #13 (permalink)
Old 02-04-2010, 07:03 PM
Faber's Avatar
noooooooooo.....
let us know what you think, appreciate the heads up.
__________________
  #14 (permalink)
Old 02-05-2010, 07:55 AM
MikeB 88's Avatar
2000 Ford Ranger
I may have had a brain fart. Filled up this morning at QT, as I forgot to go Shell and didn't want to back track. This past tank I got 21.5mpg's. The tank before I got 22.6 mpg's. Down 1mpg, could be just the weather. I'll see what I get with QT's gas in 3 or 4 weeks.
__________________
Mike B
  #15 (permalink)
Old 02-05-2010, 06:40 PM
Faber's Avatar
happens to the best of us....
__________________
Tags
2010, 88, 94, buy, ethanol, find, fuel, gas, gasoline, line, oklahoma, owasso, real, shell, thunderbird, tulsa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
