Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 08:19 PM
eXtremeYJ eXtremeYJ is offline
eXtremeYJ is starting off with a positive reputation.
1975 F250 highboy need help w/ gear ratio
hello fellas, just picked up a 1975 f250 highboy last weekend because the axles are a bolt right for my 88 jeep wrangler, im haveing issues finding the gear ratio, but have heard that the ratios possible 4.10?? any help would be great!! thanks, mike
heres a pic
  #2 (permalink)
Old 10-26-2009, 08:29 PM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
1) If the warranty plate found on the driver's side door below the latch, post the AXLE code.
2) Scrap off the axle tubes as much as you can and get the BOM.
3) If they are still there, post the axle tags found bolted onto a cover bolt.
4) Do it old-fashioned way - driveshaft rotation.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #3 (permalink)
Old 10-26-2009, 08:39 PM
the waranty plate axle code is 24j
front axle tag is still bolted and it reads c8ta dj 603037 1
  #4 (permalink)
Old 10-26-2009, 08:54 PM
24J = Dana 60 rear axle / 4.10 ratio / 5300lbs capacity / open differential. J = With power steering.
ID and BOM on the front axle tells me it was out from an earlier truck.
C8TA = 1968 truck. 603037-1 = 1968/69 F250 3/4 tonner / 4.09 ratio / open differential
__________________
Chad
  #5 (permalink)
Old 10-26-2009, 09:07 PM
thank you!! also u wouldnt happen to know if i can do a disc brake setup with that closed knuckle setup or have to get a new axle
  #6 (permalink)
Old 10-26-2009, 09:13 PM
First year for disc front brakes on F250 4WD = 1976.
Not sure if they still used the closed knuckle design by then...
In my case, I would opt for a '78/'79 front axle over the earlier ones.
__________________
Chad
  #7 (permalink)
Old 10-26-2009, 09:23 PM
ill have to look into it thanks
  #8 (permalink)
Old 10-26-2009, 09:24 PM
montana_highboy's Avatar
montana_highboy montana_highboy is offline
montana_highboy is gaining momentum as a positive member of FTE.
Quote:
4x4 Front Differential Disc Brake Kits
__________________
75 Highboy 390 4spd
  #9 (permalink)
Old 10-26-2009, 09:36 PM
Quote:
Originally Posted by montana_highboy View Post
with price of that i could probably find a dana 60 already with disc brakes, do they have rear disc conversions too?
  #10 (permalink)
Old 10-26-2009, 10:44 PM
460/5's Avatar
460/5 460/5 is offline
460/5 is starting off with a positive reputation.
ya know. ill bet you could built that old ford up, and have full size rig thats better off road than your jeep. :-P just a thought for ya.
__________________
Trey, aka Stretch, aka Slim, aka Shorty, aka Seven-Footer, aka Daddy Longlegs.
'91 F250 red long box super cab w/ 460, 5 speed, 4x4.
'76 F100 tan custom single cab short bed w/ 360, 4 speed, NP205 4x4.
'78 F150 white single cab long bed w/ 400, C6, NP205 4x4.
Imagine what I could do if I had all my brain cells.
  #11 (permalink)
Old 10-26-2009, 11:17 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
If you are looking for strength, you do not want that low pinion front axle with drum brakes.
Even in a Jeep there are much better axles out there. Matter of fact, just about any other front axle is going to be better and less expensive to build.
That dana 60 rear axle is only a 30 spline axle, and while this can be upgraded by boring the spindles, it is not the best or first choice of many off roaders.
Going "full width" is super cool, but other axles are of superior design and a far better choice for this conversion.
You can build your own rear disc brake conversion for your D60. YOu just need some caliper brackets to bolt up to the axle flange (the ones I make bolt up and do no weld to the tube), then use a chebby front caliper from say a 1980 K20. Buy the rotor for this vehicle as well. KNock the studs out of the hub, and remove the drum. Replace the rum with a rotor, and install the caliper. Viola,,,,,instant disc brakes.
Either way, you might consider a different 3/4 ton axle.
  #12 (permalink)
Old 10-27-2009, 06:13 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Front Axle: C8TA-DJ = 1968 F250 Dana 44-6CF.
This front driving axle is not original for any 1975 F250, it's been swapped in.
Rear Axle 24: Dana 60. But...
All 1973/74 F250's, 1975 F250's before serial number W20,001 = 16 spline axle shafts.
1975 F250's from serial number W20,001, all 1976/79 F250's = 30 spline axle shafts.
Since the front driving axle isn't the original, is the rear axle the original?
1973 and later Dana 60's: The Dana ID tag is bolted to the axle housing to the left of the inspection cover on 2WD's, to the right on 4WD's.
The rectangular ID tag is 2" x 1/2" two bolts are used to retain it.
The ID code will be composed of seven or eight numbers...like these two examples: 603010-1 or 603010-11.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #13 (permalink)
Old 10-27-2009, 04:45 PM
there is no more tag on the rear, seems the cover has been removed before
Quote:
and the trucks already gone anyways
  #14 (permalink)
Old 10-27-2009, 07:41 PM
Ford Parts Guru
there is no more tag on the rear, seems the cover has been removed before, and the trucks already gone anyways
What does the (inspection) cover have to do with the Dana ID tag?
Nothing.
The Ford axle ID tag is under one of the bolts that holds the inspection cover to the housing. Usually...by now...it is missing.
Quote:
1973 and later: The Dana ID tag is bolted to the axle housing, to the left of the inspection cover on 2WD's, to the right on 4WD's.
__________________
  #15 (permalink)
Old 10-27-2009, 07:45 PM
like i said above its not there cause the cover has been removed before
Tags
1975 , 1978 , 69 , brake , convertion , disk , f100 , f250 , finding , ford , gear , price , ranger , ratio , speed , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
