I would really like to have a chrome grille for my 55. Has anyone had theres chromed? Did you have to drill the spotwelds and disassemble it or could it be chromed in one piece? If you disassembled it how did you get to the center welds where the two top bars come together?
Or I will go out on a limb and ask does anyone have an extra laying around?
Thanks
Had mine chromed in Edmonton (Fairmont). They took it apart and stripped it and then somewhat put it back together. Looks good but still isn't back on the truck as the new motor isn't in either.......
__________________
_______________________________________________
Sharon 55 Mercury M-100
07 Toyota Tundra 5.7L aka the Hemi Eater, 09 Toyota Venza AWD V6, 07 Suzuki C90SE Boulevard 1500 Might as well spend it, you can't take it with you!
Plating does not do well in tight corners. So to do a good job, the grille must come apart, the pieces plated, then bolted back together where the spot welds were.
What did it cost to have your grill re chromed Sharon? Was it a good job?
Pretty expensive in my books @ $400. But they took it apart, stripped it and fixed any minor dings etc and then put it back together after. So I guess it wasn't bad. It was a pretty good job. Maybe not show quality but that wasn't what I was looking for anyway.
__________________
