Where to get coolant test strips? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-26-2009, 07:45 PM
DAI532's Avatar
DAI532 DAI532 is offline
DAI532 is gaining momentum as a positive member of FTE.
I have an early 99 PSD and need to flush my coolant. I have been to all the local auto parts stores, including the national ones, and they all seem to act like I am crazy when I ask for the test strips. I went to a local stealership and they did not have them either. I did buy some of the SCA additive there and they told me just to add one pint to four gallons of coolant concentrate and four gallons of distilled water. They said it would be close enough to approximate it. Well, I trust NOTHING the dealer says. In dealer language, that means, "don't use enough and you will be back here for us to sell you new engine."
Anyone know where to buy the strips that measure the SCA amount?
Old 10-26-2009, 07:51 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.
Go to a big truck stop or most any where they work on tractor trailers. I get a couple free from a truck stop off the interstate. NAPA has them but you have to buy a large quantity.
Old 10-26-2009, 07:52 PM
OTTOMATIC OTTOMATIC is offline
OTTOMATIC is starting off with a positive reputation.
Peach State Freightliner
1755 Dry Pond Road
Jefferson, GA
Old 10-26-2009, 07:58 PM
huntke's Avatar
huntke huntke is offline
huntke is starting off with a positive reputation.
I get mine from the local intenational truck dealer. IIRC they are like a dollar and some change each.
Old 10-26-2009, 08:05 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
You might be able to use the ELC coolant. I think they had a service bulletin on what years. Then you don't have to mess with it.
Old 10-26-2009, 08:11 PM
DAI532's Avatar
Quote:
My manufacture date is 01/99 and the post I read by Gooch about the flush says only after 2/99 can use ELC. Has that information changed?
Old 10-26-2009, 08:27 PM
maevans's Avatar
maevans maevans is offline
maevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud of
If you have no luck finding the test strips, Let me know, there is a IH dealer close to my work and I can send them to you.
Old 10-26-2009, 08:46 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
In my opinion, no. I'd avoid it. You can order the test strips from NAPA or Carquest. Don't waste money on any of the fancy kits. Just order the cheap one that is a bottle full of little strips. The bottle has the color chart on the outside, and you just need to dunk the strips in the coolant and watch the colors.
Then, if needed, add some SCA, drive around a bit and re-test. Repeats necessary until all checks out good.
Old 10-26-2009, 09:07 PM
American Air-1's Avatar
American Air-1 American Air-1 is offline
American Air-1 is gaining momentum as a positive member of FTE.
I give up...what is SCA?...and why can't you use ELC for the earlier PSD?
Old 10-26-2009, 09:08 PM
DAI532's Avatar
Ok. Thanks guys. I will try a few of the places you have mentioned.
Old 10-26-2009, 09:15 PM
DAI532's Avatar
Quote:
SCA is an additive you add to the coolant to prevent cavitation ( a process by which tiny air bubbles vibrate the inside of your engine causing erosion, injector cup failure, block failure, etc.)
Engines built after 2/99 apparently have different seals, gaskets, etc. that are compatible with the newer ELC coolants which do not require the SCA additive. Engines built before 2/99 can possible run a risk of having issues if used with ELC coolants.
If I did not explain it all that well, then I am sure someone will correct me with a more accurate information or explanation.
Old 10-26-2009, 10:36 PM
I have been using ELC since 2001 or 100,000 mi. , build date on motor 2/19/98. . In fact i just changed coolant again today and used ELC. But i only have 323,700 mi on truck so it's hard to say if the ELC is damaging it.
Old 10-27-2009, 01:09 AM
Rockrunner86's Avatar
Rockrunner86 Rockrunner86 is offline
Rockrunner86 is starting off with a positive reputation.
My local Napa sells the strips.. But I switched to the Delo red long life and will never look back..
Old 10-27-2009, 02:21 AM
hucka1a's Avatar
hucka1a hucka1a is offline
hucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to all
Old 10-27-2009, 02:23 AM
hucka1a's Avatar
Quote:
Thanks Mark for the strips you sent me.
Coolant compatibility ? TOMMAY Cooling, Heating, Ventilation & A/C 7 03-05-2015 10:55 PM
coolant test strips--where to buy? One Sock General Diesel Discussion 4 12-18-2013 07:53 PM
Test strip confusion.... SB93 F350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 11-01-2010 08:41 AM
Rotella extended life coolant ??? chipper 1999 - 2003 7.3L Power Stroke Diesel 14 06-08-2004 02:38 PM
Where can I buy the SCA test strips? TJC1989 1999 - 2003 7.3L Power Stroke Diesel 10 12-05-2003 07:55 PM
Tags
73, additive, cc2602a, coolant, crankcase, diesel, fleetguard, ford, itp, kit, napa, powerstroke, ps, sca, strips, test, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
