Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 07:20 PM
86stepsideF150 86stepsideF150 is offline
86stepsideF150 is starting off with a positive reputation.
Bad oxygen sensor
I used a BOB on my truck last week and discovered that my O2 is reading .030V in and out of the computer regardless of rpm with the engine warm. Any recommendations on a new O2 sensor? There are many options ranging from a $16 Bosh to a $90 Ford Racing sensor. I assume Motorcraft or Ford Racing would be the best, but is the brand or price really important?
__________________
1986 Ford F150 Flare-side pick-up. Two tone paint, cruise control, power windows, power locks, heat, A/C, 302 EFI, automatic overdrive trans, 4x4. Upgrades: Pioneer stereo & speakers, fog lights, tow hitch, front tow hooks, 31" tires, 16" Cragar black steelies, true dual exhaust, cold air intake, hot ignition system, chrome valve covers.
  #2 (permalink)
Old 10-26-2009, 09:04 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
Bosch is the Original equipment manufacturer for the O2 sensors back in the day. The original on mine was stamped. "Motorcraft, MFG: by Bosch".
If you get the Bosch OE one, it should work the same as the motorcraft one.
  #3 (permalink)
Old 10-26-2009, 09:23 PM
Hmm I didn't know that. That's interesting. So, the $16 dollar Bosch should do just fine then. Thanks, I appreciate it.
After towing a '69 VW bug on a car dolly today my truck has not wanted to idle. It idles really rough and keeps stalling in Drive. I am suspicious of my IAC valve, or TPS sensor. I'll change the O2 and go from there.
__________________
  #4 (permalink)
Old 11-02-2009, 07:20 PM
I discovered that the vacuum line going to my EGR had melted on the heat riser pipe. I repaired the vac line and needless to say the truck idles much better.
I am considering switching to a 3 wire (heated) O2 sensor. I am thinking a heated O2 would work better since I relocated the O2 farther away from the engine when I switched to headers. It is now located in the reducer of my passenger side header collector. All I would have to do is connect the signal wire, connect a ground, and connect a hot in run power source. Am I over thinking, or would this conversion be worth doing?
__________________
  #5 (permalink)
__________________
Tags
1986 , air , cold , f150 , fod , ford , iac , intake , motorcraft , o2 , oxygen , price , sensor , truck , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
