Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 06:59 PM
gearloose1 gearloose1 is offline
gearloose1 is starting off with a positive reputation.
What is reasonable warmup time from freezing start?
Hi,
Would everyone please let me know what is a reasonable amount of time for the Diesel to be warmed up under these conditions?
- No plug in.
- Cold start at 28F (just below freezing)
- Engine started when the heater light goes off, starts in about 15 seconds of cranking.
- Driven slowly around 30 to 40 mph, city driving.
- no rad shield.
I am getting this:
2.5 miles to point when gauge jumps to the first mark.
5 miles to the 2nd notch on the temp gauge
10 or more miles to full warm up with gauge in middle of range.
Is this normal? Do I need a hotter thermostat?
Thanks
  #2 (permalink)
Old 10-26-2009, 08:18 PM
senix's Avatar
senix senix is online now
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
Normal. Diesel does not heat like a car would. It will take longer. Best course of action seems to be what you are doing. Start it, give it a second or two and then start out slowly.
15 seconds is a bit long on the cranking. What year/motor do you have?
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #3 (permalink)
Old 10-27-2009, 09:29 AM
hanklin's Avatar
hanklin hanklin is online now
hanklin has a good reputation on FTE. hanklin has a good reputation on FTE. hanklin has a good reputation on FTE.
if you can,let it idle and warm up a bit more. Of couse plug in is best but you know that. Try cycling the wts light twice to heat glow plugs up a little hotter,it mat shorten cranking time
__________________
2001 7.3l F-444(Monkey Wrench Racing) PSD 4x4 SC ;stainless ruenel bumper,glasstite,exhaust,superchip autometer cobalt gauges,tymar,sonnax ,zoodad mod:-Line-X , 5er:
even a blind pig finds mud now & again
  #4 (permalink)
Old 10-27-2009, 09:58 AM
senix's Avatar
Quote:
Good tip!, I have to spread the love or I'd rep ya.
__________________
  #5 (permalink)
Old 10-27-2009, 10:03 AM
Thanks to everyone that replied!
I have a 2005 E-350 6.0 PSD.
Yes, the cranking seem a bit longer than it should be.
What I am going to do is:
a) try cycling the glow plugs twice.
failing that, replace all of them.
Thanks again!
  #6 (permalink)
Old 10-27-2009, 10:46 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
You may also check to make sure you have the latest software flashes in the computer. Ford has an inductive heat flash that addresses some of the cold start issues folks have experienced with the 6.0. Mine got the flash a couple of months ago while it was in for service and it has made a big difference in the cold starts. The coldest it's been here so far is around 30F but I could tell a big difference.
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #7 (permalink)
Old 10-28-2009, 08:00 PM
slowmans slowmans is offline
slowmans is starting off with a positive reputation.
start running a 5-40 synthetic oil, your starts will be much better.
__________________
2006 F350 LARIAT 6.0 SUPERCAB 4X4 FX4
4"MBRP T-409 TURBO BACK COOL DUALS
EDELBROCK PERFORMER IAS SHOCKS
ACCUFAB POLISHED INTAKE ELBOW
KITTY IS AT THE VET!!!
305/65/18 BFG ALL-TERRAINS
DRINKING B-5 REGULARLY
08' REAR DIFF. COVER
  #8 (permalink)
Old 10-29-2009, 06:58 AM
hanklin's Avatar
I just think you need to plug in and/or let it idle to warm up but before you change all the glow plugs see if you are throwing any codes. Could be harness or just a single plug,but start there
__________________
  #9 (permalink)
Old 11-05-2009, 06:30 PM
smlford's Avatar
smlford smlford is offline
smlford is starting off with a positive reputation.
In addition to the good suggestions above I'd add putting a cover over the grill like the one I use from Cabelas when it dips below freezing. It makes the warm up much quicker...
Cabela's -- Winter/Summer Truck Grille Covers and Screen Fronts
__________________
Eddie
2006 F-350 XLT Larriat 4X4 CC PSD - OEM 20"wheels, Spray in Bed Liner, Pace-Edwards Toneau, Fumoto valve, Coolant Bypass filter, Hidden Hitch
2007 Ranger XL 2.3 -2WD, Auto, Short Bed, The Beast !
Build Green ! www.PDandM.com
  #10 (permalink)
Old 11-06-2009, 11:02 AM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
When it does start after that 15 seconds...is there a lot of white smoke (unburnt fuel/gp/gpr related)?
My '97 is starting in about 2 seconds, with about the same warm up time. I've still got my 15w40 in it, and we had snow sticking on the ground last night.
__________________
1997 F250 HD XLT, 4x4, auto, 4.10 limited slip 265/75 KM2s approaching 300k mi
2002 Escape XLT, auto, tow package, Cooper disco STTs, ~80k mi
  #11 (permalink)
Old 11-07-2009, 03:13 PM
juneau76's Avatar
juneau76 juneau76 is offline
2003 Ford F-250
My Garage
juneau76 is gaining momentum as a positive member of FTE.
Quote:
Rep'd him for you.
__________________
Brad
2003 F-250 Lariat Supercab 4x4 6.0L PSD, Fumoto, Updated HFCM Plug, DieselSite Bypass Coolant Filter, 22" Wiper Blades, more to come...
2008 Taurus X Limited AWD w/ a Fumoto (The Wife's Family Truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #12 (permalink)
Old 11-07-2009, 08:19 PM
Thanks to everyone who responded!
  #13 (permalink)
Old 11-08-2009, 08:27 AM
hanklin's Avatar
Just a little side note:
I`ve got a battery goin down. If I don`t plug in then in the morning I have to jump start. Started 4 days ago,looks like I`ll be buying 2 new on Mon
__________________
  #14 (permalink)
Old 11-08-2009, 08:50 AM
What batteries are you going to be buying?
Any recommendations?
What about putting in real truck (or golf cart batteries in?)
It is technically possible to put 2 6v golf cart batteries in series.
What is the biggest battery you can put in?
  #15 (permalink)
Old 11-09-2009, 06:06 PM
solaratomic solaratomic is offline
solaratomic is starting off with a positive reputation.
If I remember correctly from the manual on my 06 6.0, it says the glow plugs actually stay on for two minutes after the key is turned to the "on" position reguardless if the engine cranks or not. The only thing I have observed as far as the glow plug light is the injectors "buzzing" or preheating in congruance with it. Sounds like your batteries are starting to go bye bye or they need water. You may wanna check your water level. It takes a good hot set of batteries to crank these psds on cold mornings. But you can plug it up and buy yourself some time before purchasing batteries, if you end up needing them.
Tags
ford , time , warmup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
