Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 05:41 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn is starting off with a positive reputation.
Is this part restrictive for air flow?
Noticed alot of guys don't have this part connecting on the air cleaner:
Is it somehow restrictive? The hood closes right on the end and only lets a very small crack for air to get through.
__________________
Driving a Diesel adds a whole new meaning to smoking the competitor!
1990 Ford F250 4x4 5 speed 4.10 gears N/A 7.3 Diesel 568,000km/375,000miles, still on the orignal clutch!
1987 Ford E350 C6 Trans 3.55 gears N/A 6.9 Diesel Motorhome 26ft. weighin' 11,000 pounds and it's slow goin' up hills lol.
  #2 (permalink)
Old 10-26-2009, 07:34 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Some have removed them........but you would then get warm/hot under hood air PULLED into the intake. With the complete thing at least you are getting cooler/cold air ingested. That said, some do put the K&N intake horn assy under hood with the filter behind the headlight area away from the rad air.
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 10-26-2009, 09:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Sorta, try this.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 10-26-2009, 09:32 PM
Lol wow Dave is that on your truck?? That's a nice redneck mod! Did you notice a differents in power, opperating temp with that?
__________________
  #5 (permalink)
Old 10-26-2009, 10:01 PM
1986 Ford F-250
I even noticed a difference with the turbo.
And the EGT dropped 100 or 200 degrees depending on the outside air temp.
4" x 10" scoop, positive pressure through the air filter to the turbo at 50 MPH.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #6 (permalink)
Old 10-26-2009, 10:40 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
yeah! this is a must do mod John.Mines going to have it before i even start running the truck.the more air you can force down a diesels throat the better lol.
this basically = free HP!
im also going to wrap my tube(s)to keep the air cooler from engine heat as every little mod adds up.
p.s. don't forget to do this too John:
http://www.ford-trucks.com/forums/540467-soup-bowl.html
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #7 (permalink)
Old 10-26-2009, 11:27 PM
morimoto_87's Avatar
morimoto_87 morimoto_87 is offline
1991 Ford F-250
morimoto_87 is starting off with a positive reputation.
what about rain and snow...do you have to put a screen or something over it in the fall and winter?
__________________
1991 F250 with a bignasty 7.3 IDI n E4OD, 3:55's, 285/75/16 UNIROYAL RADIALS
  #8 (permalink)
Old 10-27-2009, 11:40 AM
dyoung14's Avatar
dyoung14 dyoung14 is offline
1986 Ford F-250
dyoung14 is starting off with a positive reputation.
that thing you circled is restrictive, look were it sits, it get almost closed off when you shut the hood,
__________________
1986 ford f250 XLT Lariat 4x4 6.9 n/a, t19,285/75/16 maxxis mudders, on gun metal grey wagon wheels,Brand new BB code injectors from typ4, rebuilt ip set to 4??? rpm, really advanced timing, glow plug delete mod, soup bowl and restrictor plate gone, equis performance water temp, and oil pressure gauges, factory tach, putting a non wastegated psd turbo on it very soon, and going to run isspro boost and pyro gauges and maybe isspro tach along with factory tach just for kicks and giggles
  #9 (permalink)
Old 10-27-2009, 05:28 PM
Mat J Mat J is online now
Mat J is starting off with a positive reputation.
even with out a turbo i noticed a big difference black smoke wise it cut down on alot before i had my pyro in.
__________________
91 F-250 7.3 N/A ZF-5 2wd, 4" ram air, Isspro gauges, IP turned up, 265/75/16 A/Ts, 15% tint, carter p4594 ele pump, 55w back up lights, class V hitch, 4" exhaust w/14" magnaflow diesel muffler, steering stabilizer (DD/hauler)
88 F-250 460 c6 4x4 Lifted on 36" TSL super swampers, stacks, MSD 6al, holley red, warn hubs (Mud truck)
  #10 (permalink)
Old 10-27-2009, 05:39 PM
Thanks but it's already gone, we removed it couple months ago.
__________________
  #11 (permalink)
Old 10-27-2009, 05:43 PM
I really gotta do this redneck mod to the 6.9 cause it smokes quiet a bit in hills, and it bothers me sometimes cause I have no idea what are my EGT's! And it would also help keep it cool, even though I never had a heating problem with it. Problem is, it's a Econoline Van body, so I don't think I have enough room to do this cheap and simple mod.....whaaaaa
__________________
  #12 (permalink)
Old 10-27-2009, 06:59 PM
1986 Ford F-250
I will say there is enough up angle in the pipe that rain is not a problem.
But snow....better take the hose off the air cleaner.
The lighter and fluffier the snow is, the worse it is.
It goes all the way in and forms ice on the filter element, choking the engine.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #13 (permalink)
Old 10-28-2009, 12:54 AM
KJLYPW's Avatar
KJLYPW KJLYPW is offline
KJLYPW is starting off with a positive reputation.
Check out my galley, built a bigger scoop to replace the OEM, and built a big difflector to drive air up under the hood from the rad area to get very effective ram air. Pics are worth a thousand works, wish I could figure how to quickly up load from the gallery!!
http://www.ford-trucks.com/user_gall...111269.520.390
__________________
Kevin L.
93 F350 7.3 IDI 4x4, E40D with Multi Disc TC, Ram air, Stans Headers, 3" to Y- 4" exhaust,3.55, B&M shift plus, Pyro, Fuel opened 1-1/2 flats- Happy with power increase!
48 F-68 Stock- in restoration
  #14 (permalink)
Old 10-28-2009, 05:25 PM
Wow man that looks great! I do love Daves redneck air intake though lol. But still, I'll have to look in the E350 6.9 next year to see if I can rig something up like that in a Van body, cause it's the one that needs it the most!
__________________
  #15 (permalink)
Old 10-28-2009, 07:35 PM
johnboggs21's Avatar
johnboggs21 johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
Figure that out the hard way?
__________________
1993 F-250HD 7.3L IDI E4OD
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
Tags
460 , 73 , 97 , air , building , ford , horns , idi , intake , ram , restrictor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
