You said the PCM was fried as well....has it been replaced? If so, where did it come from, and was it flashed for the correct truck? It sounds like the HPOP is doing its job, and you are getting fuel through the injectors, so unless the new injectors are bad, we can rule those systems out. It's starting to sound like either and IDM or PCM problem. Can you get a loaner PCM out of a buddies truck and try it?
