Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 05:15 PM
timothyr timothyr is offline
timothyr is starting off with a positive reputation.
GP removal help...
86, 6.9 NA ...so I have all replaced but 2, the ones directly under the fuel line supports. I do not have a tool to get in there (offset wrenches are not offset enough, deep sockets to tall etc.). Is there a reson not to remove the fuel lines, and if not what kind of issues am I going to run into when I put it all back together.
__________________
86 F350 Crew Cab Dually - 6.9l IDI w/a 4-spd
  #2 (permalink)
Old 10-26-2009, 05:33 PM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh is starting off with a positive reputation.
if im thinkin correctly i just popped the fuel line keepers off and slid a 1/4" extension between the fuel lines
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
  #3 (permalink)
Old 10-26-2009, 09:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
And after the glow plug is loose, a short 6" piece of 1/4" fuel line will turn the glow plug and pull it out.
Same trick puts the new one back in the hole.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 10-26-2009, 09:36 PM
was able to get in and do the left bank no problem using the fuel line trick, but can't seem to get anything in on the right (passanger)...if I had another 1/4" of wiggle room I'd be done.
If I pop the lines what other mess am I going to open up?
__________________
  #5 (permalink)
Old 10-26-2009, 10:07 PM
1986 Ford F-250
Possibly the return lines.
Just try very hard to not disturb them, loosen the line in the way and move it as little as possible.
Be careful as you start to loosen the injection line nut, make sure it turns on the injection line so you don't crimp the line.
They get a little stuck sometimes, so if you are not watching you can damage the injection line, which cost close to 50 dollars each.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #6 (permalink)
Old 10-27-2009, 11:05 AM
Dave, this brings me to another thought....just on the right side there is a little fuel in 2 of the glow plug wells....the injectors, and the piece that the return line connects to look new, but the lines were clearly not replaced at the same time.
when mentioning age, I am using grime as the judge...the injector assemblies are prestine, the braided cable going up to it is filthy and tattered (along with the rest of the enigine compartment)
__________________
  #7 (permalink)
Old 10-27-2009, 06:21 PM
1986 Ford F-250
Sounds like return lines and O rings will be your next project.
How is the engine starting after it sits for a while?
Start then stumble or stop after about 15 seconds running indicates air in the filter.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #8 (permalink)
Old 10-28-2009, 02:42 AM
other than the gp issue she is running fine...I deffinatly am going to replace the return lines in the next week; they almost look original. Do you have an exploded view of the injeector and return line assy. from what I can tell, it looks like there is a return fitting that screws into the injector itself. If that is the case, the po replaced everything except the rubber lines that runs between them
__________________
  #9 (permalink)
Old 10-28-2009, 03:55 PM
fatkid89704 fatkid89704 is offline
fatkid89704 is starting off with a positive reputation.
i just did my glow plugs and the easiest way i found t get the two center ones out was to use 1/4" drive with a deep socket and a universal joint just above the deep socket.and putting them back in with the fuel line is the easiest way to go.be sure to test all your glow plugs and keep the good ones just in case you need one in the future.
  #10 (permalink)
Old 10-28-2009, 05:26 PM
what is the easiest way to test them outside the truck?
__________________
  #11 (permalink)
Old 10-28-2009, 05:53 PM
use a volt ohm meter and check the ohm resistance of the plug.touch one lead to the threads and the other to the wire connector on the end.it should be between 0.5 and 1.0 ohms.any higher then that and the plug is bad.hope this helps.
  #12 (permalink)
Old 10-28-2009, 06:28 PM
thanks....it does
__________________
  #13 (permalink)
Old 10-28-2009, 10:32 PM
1986 Ford F-250
The return line caps on the injectors have two O rings under each of them.
There are grooves in the top of the injector where the O rings are installed.
Inside the caps, there are very slight depressions that the O rings kinda snap into when you reinstall the caps.
Starting at the far right, the threads for the injection line nuts.
Just to the left of that, first O ring groove.
Then the raised part with the bleed hole drilled in it.
Then the second O ring groove.
Use care not to scratch or damage the injector when you remove the old O rings.
Oil the O rings before you install them.
Install the top O ring first, then the bottom one.
Just roll the bottom one across the top O ring till it gets to the bottom groove.
Oil the inside of the return tees before you install them, press down firmly but watch the line nipples.
You will feel a slight snap when they seat.
Some people build the return lines and then install the whole side, others build them on the engine.
I have done it both ways, about the same to me either way.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #14 (permalink)
Old 10-28-2009, 11:11 PM
thanks dave...that is exactly what I was looking for; and this project is now on...2 cracked return lines and now leaking fuel all over....but hey, the glow plug system works
still wouldnt trade my idi for anything
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
