Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 03:01 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
C6 shifts at 4500rpm.
I've only recently been able to drive my 86 F-250. I'm not a fan of autos and haven't had to work on one in a long time. I have noticed that when driving, my C6 wont shift until it's about 4500rpm under mild accelleration. If I release the pedal, it will shift. It just seems like it's waiting a long time to shift during regular driving. The trans only has about 60k miles, I did verify the vacumn lines were intact to the modulator and the kickdown rod is still in place. Stupidly though I still haven't checked the fluid level. I need to pull the pan anyway as it has a good dent in it, gonna put in a new filter in as well. Would a low fluid level cause this? I was also wondering which way to adjust the modulator to make it shift sooner.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #2 (permalink)
Old 10-26-2009, 04:32 PM
Lazy K Lazy K is online now
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
Pull the vacuum pipe off the modulator and look for signs of Fluid in it. If you find any replace the modulator.
Low fluid may be a cause.
  #3 (permalink)
Old 10-26-2009, 09:21 PM
1993 Ford F-250
I did check that, and the hose was dry. I was going to check the fluid today, but the weather sucks and I got lazy. If the weather changes tomorrow, I will check the current level before I drop the pan.
__________________
  #4 (permalink)
Old 10-27-2009, 10:14 PM
fatboyf150's Avatar
fatboyf150 fatboyf150 is offline
fatboyf150 is starting off with a positive reputation.
sounds like you need to adjust the modulator. pull the vac line off and look down the tube. you should see a little turn screw.
__________________
FOUR WHEELING - certainly the most fun you will have with your clothes on!!!
2000 ranger 3.0 auto tranny extended cab 4x4 315/70/16 goodyear mtr's
95 f150 351w 3in body lift, 38.5 swampers
coastalcarolinaoffroad com
  #5 (permalink)
Old 11-03-2009, 03:16 AM
1993 Ford F-250
Which way do I turn the screw to bring the shift points down?
I finally changed the filter, the fluid didn't smell to bad but was a little browner that I hoped. The pan was clean as was the old filter, no shavings of any kind. I wasn't able to drive it yet as I had to pull the alternator to get it tested. Should have it going again tomorrow.
__________________
  #6 (permalink)
Old 11-04-2009, 08:55 AM
Have you definately got vacuum at the pipe? With trans in Park and engine running pull the pipe off at the trans, does the engine note change? If so vacuum is good and modulator is not leaking.
Next I would be thinking of pulling the vacuum modulator and applying a vacuum to it and see if it is working.
  #7 (permalink)
Old 11-04-2009, 11:17 AM
1993 Ford F-250
Ok, I'll check out the vacumn and the modulator. I did drive the truck today, fluid level is now verified but it drives the same as before.
__________________
Tags
2002 , 250 , c6 , ford , modulator , vacume
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
