Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 01:52 PM
thumper869's Avatar
thumper869 thumper869 is offline
1997 Ford F-250
thumper869 is starting off with a positive reputation.
starter problems
alright my starter has issues but i'm not sure if its the wiring to the starter, the solenoid on the starter, flywheel, or the starter itsself.
when i go to crank it sometimes it'll start right up and othertimes i'll turn the key the starter will kick over but it doesn't engage the flywheel and sounds like its grinding almost. sometimes it does this as many as ten times before it turns the engine over to start it.
i redid the hot cable off the battery the wire off the solenoid up top and the ground cable on the starter. also i pulled the starter off checked what i could see of the flywheel from there no chipped teeth and no shavings checked the mounting face on the bellhousing and on the starter no problems there. even adjusted the alignment of the starter a few times by loosening my bottom bolts and crankin down more on the top one then tightening the bottom ones back up.
i'm all out of ideas other than replacing the starter altogether. luckily its got a lifetime warranty on it, but heck i just put this one on 11 months ago.
and the starter currently on it is the third on it since i've had it. i replaced the starter that was on it when i bought(bought it in 06) it in july 07 and replaced that starter in november of 08 this seems to be an every year thing. except the original starter the solenoid on it melted down and on the second starter the hot bolt broke loose of its connection on the inside of the solenoid on the starter.
what do ya'll think?
  #2 (permalink)
Old 10-26-2009, 02:27 PM
Action4478's Avatar
Action4478 Action4478 is offline
taH ssA
Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE.
I went through this a few years back with an older truck , at least 12 starters & 2 (ruined flywheels) . I put a ford starter in it & haven't had to touch it since (19 years )...
Oops , I forgot , I had to replace the cover on the bendix, it rusted out from age , that was 3-4 years ago ...
__________________
Rick.......
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
  #3 (permalink)
Old 10-27-2009, 01:22 AM
thumper869's Avatar
1997 Ford F-250
could it possibly be the brushes or windings in the starter not allowing enough electrical flow?
the factory keyless entry and the starter solenoid on the fender wall hiccuped earlier today. could that have anything to do with it?
  #4 (permalink)
Old 10-27-2009, 02:17 AM
Oversize's Avatar
Oversize Oversize is offline
1996 Ford F-250
Oversize is gaining momentum as a positive member of FTE.
The way you described it to me Id say its either the starter has bad teeth or the flywheel teeth are damaged and barely turns and you have to move it t find somewhaer it grabs long enough to spin the motor and start. Also if you keep going through starters with the same problem Id think flywheel.
__________________
96 F-250 HD, SC, LB, 7.3 DI Diesel, 5 spd, 6" lift, 35" AT's, 3" DP, cat gut, 6" straight pipe, 4.10's, FPR shim, custom intake, Hot pedal, HPX, Pyro, Boost, ...
Professional driver, Former CAT and Industrial Mech, P/T race engineer.
Tags
diesel , engages , grinds , solenoid , starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
