1991 ford f150 4x4 -5.0 /fuel pressure - Ford Truck Enthusiasts Forums
Old 10-26-2009, 10:44 AM
fordboy16 fordboy16 is offline
fordboy16 is starting off with a positive reputation.
i have a 1991 ford f150 4x4 with a 5.0 v8 could any one tell me what kind of fuel pressure this would have
Old 10-26-2009, 08:29 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Old 10-27-2009, 06:05 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
32-34 PSI at idle.
around 40 PSI WOT.
42-45 psi with vacuum hose off and plugged from the Fuel Pressure Regulator (FPR).
New Member from the Shenandoah Valley, Virginia martinhd35 New Member Introductions 1 04-16-2016 06:57 PM
Trans swap 4r70w for E4OD joshuahaney 1987 - 1996 F150 & Larger F-Series Trucks 2 12-09-2012 09:22 AM
Flue pressure, 28 PSI too low? 91 5.0 F150 4X4 ken2400 1987 - 1996 F150 & Larger F-Series Trucks 4 05-08-2010 06:35 AM
1991 5.0 F-150 Depressurizing Fuel Lines vf78ot 1987 - 1996 F150 & Larger F-Series Trucks 4 10-13-2003 06:45 PM
1991 F150 Rearend Oil Capacity rllane Oil & Lubrication 1 03-21-2003 08:36 AM
Tags
1991, 351w, 49, 4x4, 50, 58, 91, f150, ford, fuel, pressure, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
