Quote:
Originally Posted by jay3403
Number Dummy, Can I get those sources from you for a 63 f-100. I am having the same problem. If I don't wiggle the shifter just right, it locks into 1st. Then I have to crawl under the truck and shift it out at the transmission.
1961/64: There are
two different kits: 2WD is
not the same as 4WD.
The following is for 2WD. If you have 4WD, let me know...I'll list that kit separately.
C3TZ7343A .. Bushing & Insulator Kit /
Obsolete
Fits: 1961/64 F100/250
2WD only.
OHIO VALLEY FORD in Moundsville WV has ONE = 304-845-4244.
MATLOCK FORD in Franklin IN has ONE = 800-987-3673.
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
GRIESEL MOTOR CO. in Okarche OK has ONE = 405-263-7242.
VAN CLEVE MOTORS in Morton WA has ONE = 360-496-5999.
MANDERBACH FORD in Temple PA has TWO = 610-929-3659.
WESLEY OBSOLETE PARTS in Liberty KY has TWO = 606-787-5293.
MILLER OBSOLETE PARTS in Binghamton NY has FOUR = 800-546-7278.
ANTIQUE AUTO SUPPLY in Arlington TX has SIX = 817-275-2381.
> > > J2H: Is your 1965 F100 2WD or 4WD?
