Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 01:30 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has a good reputation on FTE. ford2go has a good reputation on FTE. ford2go has a good reputation on FTE.
Kohler rant
OK, I've got to do this.
I have a new Cub Cadet with a Kohler Courage engine. I've had K series Kohlers for years, and they're great. The Courage seems fine, but I have a little issue with it.
The carb and fuel pump are behind the base of the air cleaner. (you can access the carb adjustments OK). In the manual it says to not remove the air cleaner base unless you have to.
What the bleep. The base is held in place by a couple of nuts. But!, for some unknown reason, you also have to take out the stud that aligns the carburetor. Also, if you take off the base, you have to readjust the throttle settings.
Kohler has been making good engines for years -- usually there's a reason for a difficult disassembly . In this case, I can only think that they did it for cost. Otherwise, they would have made removing the air cleaner base the simple job that you'd think it would be.
__________________
ford2go (hj)
Wish I had -- F150 I6 5 speed
Have E350 RV
  #2 (permalink)
Old 10-27-2009, 07:17 AM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Exiled from the club.
Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold
It isn't one of those cheap, foreign made motors that will blow up well before you have to worry about adjusting the carb or changing the air-cleaner, is it?
I was looking at snow-blowers the other day and the motors have no name at all on them. Gee, I wonder where they were made?
__________________
Ray
'97 F250 XL, 5.8L, '05 Escape Hybrid, '06 Escape Hybrid
  #3 (permalink)
Old 10-31-2009, 10:52 AM
Lead Head Lead Head is online now
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
The Kohler Courage engines are decent enough engines, but you also have to remember they are Kohler's "value" line of engines. Their Command engines are their premium line these days, I'm not sure if the Commands are any easier to work on however.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
Tags
carburetor , courage , kohler , removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
