Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 01:15 AM
IsoGrifo's Avatar
IsoGrifo IsoGrifo is offline
IsoGrifo is starting off with a positive reputation.
tire size
What would be a good tire size. lookin for radials something close to stock height but a bit skinnier for gas mileage.
  #2 (permalink)
Old 10-26-2009, 01:21 AM
63' f100 63' f100 is online now
63' f100 is starting off with a positive reputation.
I don't know what size original is, but i just bought some 275/35/r15 tires for my f100. you might look at them.
  #3 (permalink)
Old 10-26-2009, 01:23 AM
IsoGrifo's Avatar
thinking a little skinnier and a little taller.
  #4 (permalink)
Old 10-26-2009, 01:24 AM
IsoGrifo's Avatar
like, some 215/70r/15
  #5 (permalink)
Old 10-26-2009, 02:45 AM
tbm3fan's Avatar
tbm3fan tbm3fan is offline
tbm3fan is gaining momentum as a positive member of FTE. tbm3fan is gaining momentum as a positive member of FTE.
I have 235/75 x 15 on mine and they are no problem with my manual steering unless you are at a dead stop.
__________________
Mike
1968 Cougar 302-4V
1968 Mustang 289-2V
1967 Parklane 410-4V
1965 F-100 360-2V
1943 USS Hornet/1945 TBM3E Avenger
  #6 (permalink)
Old 10-26-2009, 11:43 AM
BarnieTrk BarnieTrk is offline
BarnieTrk is starting off with a positive reputation.
I believe actual tire sizes vary somewhat with each tire manufacturer.
As a rule of thumb, if you look at the various tire size comparison charts available, a 215 / 70-15 tire will be appoximately 1" shorter and 0.75" narrower than most 235 / 75-15 tires. I prefer the look of the 235 / 75-15 myself. I think it fills the wheel well nicely.
If I were buying wheels as well, I'd be looking at 16" wheels; as 15" wheels aren't as prevalent on many of the newer vehicles in a few years now, so the tire selection is better with 16" tires. If you already have wheels, make sure you know what width they are; that will narrow your selection as to what tires are designed to be run on them. Example: Last Spring, I was going to buy some narrower tires for my '65 F250, but when I spoke with the tire dealer they told me that the tire warranty would be void if I had them mounted on my rims. My rims were wider than what their recommended specifications allowed. So I bought the wider tire to ensure their warranty and load rating capacities would be upheld.
Lastly, be aware that if you vary your tire height much from OEM height, it WILL change what your speedometer reads........ both in mph and on the odometer.
BarnieTrk
__________________
- 2WD '65 F100 short box, 390" FE, T-18 4spd
- 2WD '65 F250 long box, 390" FE, T170FT 4spd OD
- 2WD '94 Ranger XLT, r/cab, 139" (2.3L) 4-cyl, 5spd
  #7 (permalink)
Old 10-26-2009, 04:46 PM
IsoGrifo's Avatar
good point about the mph, what was stock size?
  #8 (permalink)
Old 10-26-2009, 06:15 PM
Brian Taylor Brian Taylor is offline
Brian Taylor is starting off with a positive reputation.
I have 215-75-15 on mine and they are close to the original size.
F series tire.
I would like to run bigger tires but first the body and drivetrain. I would run a 275 or 295 18" rears with a bit mor wheel well and 255 17" in the front for a good stagger.
  #9 (permalink)
Old 10-26-2009, 06:22 PM
ABA's Avatar
ABA ABA is offline
ABA is starting off with a positive reputation.
275x60x15 on all 4 corners....I want as much rubber on the road as I can get
__________________
'65 F100 352 Auto Headers Power Steering
'65 F100 429 Project: Auto Headers Power Steering Power Brakes '64 Upper Valence.....
  #10 (permalink)
Old 10-26-2009, 09:03 PM
Quote:
ABA,
Does that wide of a tire rub on the inside when you turn into a sharp driveway?
I'm thinking those must have a thread width of close to 10.75"...
Maybe you're running a wheel with lots of offset?
The tires I have on my '65 F250 (
COOPER DISCOVERER AST, 9.50R-16.5LT, D-rating, with a 6.7" tread width)
are about two inches taller, but they aren't that wide and they rub on the inside of the wheel well if I turn the wheel all the way to the right or left.
BarnieTrk
__________________
  #11 (permalink)
Old 10-26-2009, 10:33 PM
ABA's Avatar
ABA ABA is offline
Quote:
Originally Posted by BarnieTrk View Post
ABA,
The tires I have on my '65 F250 ( COOPER DISCOVERER AST, 9.50R-16.5LT, D-rating, with a 6.7" tread width)
BarnieTrk
Nope no rub at all on the front and the rears are so close you can't stick your finger between the tire and the fender.
Bridgestone Dueller HP on old school "real" Centerline rims.
__________________
Tags
1961 , 1966 , 1967 , 1969 , 63 , 65 , 66 , f100 , ford , oem , selector , size , sizes , tire , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
