Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 12:39 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry jimwilsonmasonry is online now
jimwilsonmasonry is starting off with a positive reputation.
did a couple things over the weekend
well i started messin with my truck this weekend at my buddys and it just so happened that he had a set of brand new blue led headlights that fit my truck so i through those in and love them at night next i thought my fuel wasnt exactly right so i pulled my spring out on my fpr and it was bent a little bit so i straightened it out and put it back in so that was good got my fuel pressure back then i was cleanin my intake y pipe and noticed that our y pipes have some nasty factory tubes hangin out further than they should so i ported it out under the supervision of my buddy who has the p&p tools but a dremel would work so i opened it up quite a bit and got a nice swirl to it and then i hooked up a amp and sub that he had in his garage as well so i can crank them country tunes up loud yea hes a good friend and as i pulled my truck out of his garage i had no brakes wtf isnt it ironic how you do good things to your truck somethin immediately goes wrong well my vaccum pump died so that cost me 98$ and a headache cuz one of the bolts were stripped out 15 minute job took an hour sorry for the long post
__________________
I have a 96 psd with 302k miles,3:55s, cc ,5" stack,e4od-shift kit ,2wd,k&n intake 3" dp, ccv mod,no cat, hotpedal,140v idm,hpx,tw 6 pos chip, gauges,maxi cool xl trans cooler,305x70x16 tires,ported intake---94 trans am lt1 lots of bolt ons
  #2 (permalink)
Old 10-26-2009, 12:50 AM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
wow, i'm glad when my vacuum pump went out it took its sweet time doing it!!! LoL. drove it for 2 days before i could get a vacuum pump for it and right as i was pulling in the gate to change it out i hit the brakes and they just BARELY got me to a stop. LoL.
sounds like you did some good stuff to it though!! and what were you talkin' about you did to the intake Y????
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #3 (permalink)
Old 10-26-2009, 12:56 AM
i just ported it out it didnt take long at all if you take it off and look in it the tubes run about a half inch past where they shold in parts just grind them down and it opens the hole quite a bit and on the tubes that hook to the plenum they are recessed out a lillte bit run grind those so they are smooth to the touch of your finger i havent drove it hard yet i doubt it helped much but peace of mind and 'free and easy down the road i go'
__________________
  #4 (permalink)
Old 10-26-2009, 01:53 AM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
I am betting my pump is probably going.
I should keep an eye out for one.
My brakes should be super good
but it feels like they are barely there. heh.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
  #5 (permalink)
Old 10-26-2009, 02:15 AM
mine was perfect before i pulled in the garage when i pulled out of the garage it was gone sounded like the piston in the pump broke or somethin
__________________
  #6 (permalink)
Old 10-26-2009, 09:26 AM
Talyn's Avatar
1994 Ford F-250
Quote:
k&n intake
That's why it broke. hahahaha. :P
Mine looks old. Doesn't look fun to replace either.
Is it easy?
__________________
  #7 (permalink)
Old 10-26-2009, 09:58 AM
Is it easy?
see them 3 bolts behind the pulley???? yaa they gotta come outta there. then you gotta pull the pulley off the pump and put the pulley on the new pump of course and put the pump on the truck. pretty simple job.
__________________
  #8 (permalink)
Old 10-26-2009, 10:26 AM
Talyn's Avatar
1994 Ford F-250
Quote:
Simple if you have a puller.
__________________
  #9 (permalink)
Old 10-26-2009, 10:50 AM
i had to borrow a puller from my buddy that is a diesel mechanic at ford. he is the only ford mechanic that isn't an idiot that i have met so far!!! LoL. so yeah a puller helps a lot. haha
__________________
  #10 (permalink)
Old 10-26-2009, 01:17 PM
Andy's250's Avatar
Andy's250 Andy's250 is offline
Andy's250 is starting off with a positive reputation.
i got a puller a long time ago i think it was at carquest or somewhere like that. it has saved me tons of headaches over the years
  #11 (permalink)
Old 10-27-2009, 01:34 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is starting off with a positive reputation.
Just put the bolts back in the holes before you press the pulley back on.
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #12 (permalink)
Old 10-27-2009, 01:42 AM
yeah it was an easy job to do but whoever put one on before stripped out the bolts and im not talking about my k&n intake im talkin about the y pipe after the turbo
__________________
  #13 (permalink)
Old 10-27-2009, 08:55 AM
william was just playin' with you on the K&N intake. LoL. he was sayin' thats the reason your vacuum pump went out. haha.
__________________
  #14 (permalink)
Old 10-27-2009, 11:36 AM
Talyn's Avatar
1994 Ford F-250
yea, letting to much dust into the system allowing the knibbler valve to open up to much due to wear and throwing the wiggly pin outa alignment with the wobbler shaft which in turn throws out the vacuum pump
__________________
  #15 (permalink)
Old 10-27-2009, 05:41 PM
strokersace's Avatar
strokersace strokersace is offline
strokersace has a good reputation on FTE. strokersace has a good reputation on FTE. strokersace has a good reputation on FTE.
Jim you need to post up some pics of those new headlights. Especially at night to see how the leds look with the parklights on and then with the headlights.
I'm looking at buying some for a white truck with the chrome trim like yours and would love to have a visual!!
__________________
02 F350 CC Dually 4x4 118K; Forged rods; headstuds; Tymar; coolant filter; 200 Amp alt; AIH Delete; Prepump/tank mods; 5" exhaust; IDM-140; x-monitor; Leveling kit; 06 leather seats f/r; 07 upfitters; custom dash; KR boards; rhinoed - FOR SALE
95 F350 CC Dually psd auto; Tymar Intake; 3" DP; Straight piped; Western Hauler - soon to be worked over...
Tags
change , f250 , ford , pump , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
