Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-26-2009, 04:25 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Good work Nick. That old sealant sure is a PITA to get off, isn't it?
Built my detector using a 3" ID pipe cap, my old E99 intake tube and an all steel schrader valve. Less then 5 bucks.
Use with caution. The cap blew out of the tube at about 40 PSI. Scared the chit out of me. I have since put 4
self tapping hex head screws with attached rubber washers right through the hose clamp band and into the cap.
Edit : I found a leaking boot between the spider and intake plenum.
  #17 (permalink)
Old 10-26-2009, 07:32 PM
big poppa's Avatar
big poppa big poppa is online now
Monitoring The Vitals
2003 Ford F-250
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
Glad you found the problem Nick, I need to build one of these, takes the guess work out of it..Nick pic and info Robin..
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 132,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
  #18 (permalink)
Old 10-26-2009, 07:46 PM
Orezona's Avatar
Orezona Orezona is online now
Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE.
Maybe you missed it in my 1st post. How do you "update" a TNBB turbo?
__________________
Tuned by POWER HUNGRY PERFORMANCE
  #19 (permalink)
Old 10-26-2009, 08:29 PM
duck fan's Avatar
duck fan duck fan is online now
Remember 4WD
duck fan has a good reputation on FTE. duck fan has a good reputation on FTE. duck fan has a good reputation on FTE.
His wheel was pretty worn. he got it second hand. He is having a new wheel put in it and other work that I'll let him elaborate on.
__________________
Peter - NHRDA# 5078 - Member of the 200K+ club
2000 Excursion 7.3 - 6637 w/ Pete's cover, van turbo w/ ceramic coated exhaust housing, ceramic coated exhaust manifolds, WW, DP tuner, Warn hubs, gauges, foil delete, 6.0 IC, powdercoated IC pipes and spider, MBRP 4" turbo back, IH up-pipes, RDP AIH delete, OBA, RDP IC boots, RDP CCV kit
  #20 (permalink)
Old 10-26-2009, 08:36 PM
Orezona's Avatar
Quote:
That is what I'm curious about.
__________________
  #21 (permalink)
Old 10-26-2009, 09:47 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Stroken it 7.3,6.0,6.4
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE.
Quote:
Woopps sorry I did. Just Ceramic coating the exhaust housing and painting the intake housing.
__________________
Nick PAA#9
08 F-450 K R 6.4 SPARTINIZED, DPF/CAT GONE, RR Boots
04 X 6.0, 08 towing mirrors, 15k hitch, Firestone air bags
01 X 7.3, TN BB turbo, Dp tuner, ITP RR, RR up pipes, 4 Dipricol gauges,MBRP 4inch, 6637,650 dash with 2 auto meeter gauges, RR boots,
95 F-250 7.3, 6637
  #22 (permalink)
Old 10-27-2009, 12:10 AM
RussB's Avatar
RussB RussB is online now
RussB is gaining momentum as a positive member of FTE.
Nice going nick ! I wish I could get close to those numbers on my boost gauge ! I guess you'll need to come up here with clay and fix my up-pipes and find all the boost leaks ! Later buddy ! Russ
__________________
Russ PAA# 25
03, 350 Lariet, 315 Toyo M/T's, 9000lb Warn winch frnt/rear recv mount, 4 ProComp halo's (frt bump), Warn man hubs, 6637 / Pete's cover, CCV, Gauges, 4" ProComp Lift, 4" SS Magnaflow , GPR LED, SS HPX, DP Tuner NS,STK,HIGH IDLE,40T,DECEL,80T,80ECO,120/ gauge switch, Overboost, Avic D3, F650 dash, Aeroforce scan gauge !
  #23 (permalink)
Old 10-27-2009, 01:15 AM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
Clydes' a ^^^^^
WA.Ranger has a good reputation on FTE. WA.Ranger has a good reputation on FTE.
Is this why I got a phone call the other night, somebody needed an intercooler?
I'm glad you got her figured out Nick, sorry I missed your call.
__________________
http://i17.photobucket.com/albums/b93/JeffC05/th_huntingjacksonmeadow007.jpgJeff
01' CC PSD LARIAT 4X4 6" Spring Superlift, 37's
Proud Member Of The Brotherhood
WW,RRP AIH delete,RRP HRX, DPTuner, ISSPRO EV2's, TCT Tranny, HH mods, DFA RR and CCK, CCV, Tymar w Pete's Cover, DB 200A, 6.0 Intercooler, AD in #8, 5" Cannon, RedHead SG,
  #24 (permalink)
Old 10-27-2009, 07:58 AM
Orezona's Avatar
Quote:
Cool thanks. I thought maybe I had missed a 'cure' for that thing's failures. Just wanted to pass it along.
Thanks.
__________________
  #25 (permalink)
Old 10-27-2009, 08:07 AM
kirkharrod kirkharrod is offline
kirkharrod is starting off with a positive reputation.
Who is this Holly?
Sorry, couldn't resist....
__________________
2002 F-250 Super Cab, 225,000 miles, 25,000 on WVO; Greasecar conversion, 140 gal grease tank, 30 plate heat exchanger, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, CAT ELC, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. ZERO grease related problems.
  #26 (permalink)
Old 11-04-2009, 10:07 PM
afonda's Avatar
afonda afonda is offline
afonda is starting off with a positive reputation.
Just curious.... what is this manifold you are talking about replacing? Do you mean a manifold gasket? or a manifold?
How hard of a job is this? How much time to allocate for this procedure?
Thanks.
__________________
2002 F250 / 7.3 PSD / 4x4 / CCV mod /
Support ORV access in Cape Hatteras Nc. Preserve our rights to accessing the beaches with our ORV's (off road vehicles) for recreational purposes. (that means fishing and swimming..etc...)
  #27 (permalink)
Old 11-04-2009, 10:32 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
Thanks.
Don't invite trouble. Most times a manifold leak is from the hose itself as the factory job for the plenum is usually sealed quite well. Our manifold sits above the valley and is connected to the plenums via hoses. There is no conventional manifold so to speak.
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #28 (permalink)
Old 11-04-2009, 10:55 PM
megawatt00's Avatar
megawatt00 megawatt00 is online now
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
Glad that you got it fixed Nick. I remember you being a bit on the frustrated side in TN with the low boost.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #29 (permalink)
Old 11-04-2009, 11:00 PM
PaysonPSD's Avatar
Support FTE
Thanks.
There is an intake plenum/manifold on each head. There is no gasket between them and the heads. They are sealed by a special Ford sealant. The turbo-charged air is fed to them via the spider. If there is a leak between the plenum(s) and the head(s) it will result in a boost leak. What Nick did was remove the plenums and old sealant and replace the plenums using new sealant to fix a boost leak. I replaced my early 99 2 1/2" plenums with later model 3" plenums when doing a turbo upgrade. Separating the plenums from the heads is diffucult without distorting the originals, that sealant is tough stuff. I bent the passenger side plenum pretty good, but was replacing it anyway so was not concerned. The driver side came off pretty easy and I did not bend that one.
To R&R the plenums you need to remove the spider and the IC tubes at the least. Once the plenums are off you need to clean off all the old sealant, reapply new sealant and then install the plenums. Of all the individual things of doing the turbo upgrade removing the old plenums, cleaning off the heads and then installing the new plenums was the worst part and took the most time. Once I got to the plenums it took me about 3 1/2 hours to complete the R&R. I was meticulous about getting all the old sealant off. A couple of the bolts at the front of the passenger side are a real PITA to remove and re-install. There is no right or left plenum, they are identical and interchangeable. There is a slot at one end so that the bolt furthest forward and inboard on the passenger side does not have to be fully removed but just loosened. If that bolt is removed it would be a royal PITA to get back in because of the limited room next to the front cover. If I had it to do over again I would have left the 2 1/2" plenums on. It has been said that the 3" plenums don't make much difference. Follow Mile's advice and Do not R&R a plenum because you think there is a leak. Make sure there is a leak.
This is best picture I have of the plemuns. You can see the round intake of each one. Notice that they are offset and turned 180° to each other, that's because the heads are offset. Something I had not realized until I got all the old turbo hardware off.
Hope this helped answer your questions.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
