Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 12:14 AM
Redneck1465 Redneck1465 is offline
Redneck1465 is starting off with a positive reputation.
Starter issue
I know this isnt a Ford and I really hope the moderators will leave this one be for a little but my uncle has a 95 Crapolier that he put a new starter in it. It cranked over properly twice and started the car but something sounded a litttle wrong. Went to start it the third time and the starter wouldnt turn off just kept cranking until he undid the battery. He's lost so I thought I would throw it up here. He told me he had to fix one of the wires because it had broke and he didnt remember which post it went to. I think he put the wire on the wrong post could that possibly be the case??
  #2 (permalink)
Old 10-26-2009, 04:24 AM
TheKirbyMan TheKirbyMan is offline
TheKirbyMan is starting off with a positive reputation.
I would check the ignition switch and the part where your key fits in and make sure it's kicking back to Run when you let go. On my truck, there's been times that it would stay in the Start position until I moved it back to Run. Happened enough times that I do that without even thinking about it, lol.
I'd also check the start solenoid or starter relay, depending on which it has.
__________________
1981 F-150 Custom 302/C6 9"
FORD: The Best Never Rest!
  #3 (permalink)
Old 10-26-2009, 08:58 AM
bashby's Avatar
bashby bashby is offline
bashby is gaining momentum as a positive member of FTE.
if it worked a couple times it must have been hooked up right, either the solenoid stuck (Bad starter) or the small wire (from switch)is touching the big one (from battery)
__________________
86 F350 2WD Duallie dump. 351W edelbrock cam, carb, d/p intake,C6, D0OE heads. 4.10 gears
  #4 (permalink)
Old 10-26-2009, 09:41 AM
texans's Avatar
texans texans is offline
texans is gaining momentum as a positive member of FTE.
I agree with bashby I have had that happen to me once
__________________
2006 F-250 Lariat C.C, 18" rockstars w/285/65 nittos, SCT w/custom tunes, Banks Ram-Air Intake, 5" MRBP exhaust w/o kitty, 2.5" levealing kit, readylift air bags, fumoto drain valve, Viper alarm with remote start, 2-10" MTX Subs, drilled and sloted front rotors, ARP studs sitting in shop waiting on other parts.
come Join the Texas Chapter!!
Scotty
  #5 (permalink)
Old 10-26-2009, 12:45 PM
He had to undo the battery to get the car to stop cranking even with the key out of the car itll still crank.
  #6 (permalink)
Old 10-26-2009, 04:00 PM
I agree with bashby and texans. You might try unhooking that wire you mentioned in your first post, and see if that changes anything.
__________________
  #7 (permalink)
Old 10-26-2009, 09:07 PM
FordNFishinLover's Avatar
FordNFishinLover FordNFishinLover is offline
FordNFishinLover is starting off with a positive reputation.
Is he sure he put the started on correctly? Such as even and straight? It fairly common to put them on slightly tilted and they wont work right.
If i were him id disconnect the wires, unbolt the starter, check it out and see if it looks sound, make sure its bolted on straight with no gap, and connect the wires back up and see if it works.
__________________
1981 Ford f-100 302 windsor/C6/3.25/9.0 rear
Bass, walleye, catfish, and trout, im tellin you now you'd better look out! You were safe in the lakes when i was home wishin. But be on your guard cause im goin fishin!
  #8 (permalink)
Old 10-26-2009, 11:57 PM
In the few hundred starters I have installed I have never had a problem with it not being put in straight and even. Its not a matter of the starter wont work. I cranks but it cranks constantly as soon as power is put to the car. Thanks Kirby and Bashby and Texans I'll have him disconnect the wire and see what happens. Wish I wasnt 800mi away at college I'd be able to take a look at it myself and see if I could figure it out. I really appreciate the help guys.
  #9 (permalink)
Old 10-27-2009, 01:56 PM
texans's Avatar
No problem let us know what he finds out
__________________
Scotty
Tags
1981 , 302 , 81 , bad , cranking , custom , f100 , f250 , ford , key , problems , relay , starter , stop , wire , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
