Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Northern Chapter
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
California, Northern Chapter Join Chapter , Leader: fastmover
Is F-150 Still King?
  #16 (permalink)
Old 10-27-2009, 03:27 PM
AnOldDog AnOldDog is offline
AnOldDog is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by fastmover View Post
Dan (Tigerdan) recommended him. We wont hold that against him.
So, you're telling us that it's Dan's fault. Again?
__________________
There is no problem that can't be solved with a liberal application of sex, tequila, money, duct tape, or high explosives, not necessarily in that order.
It wouldn't be fun if it were easy, but does it have to be this much fun?
I don't know when I realized that I had grown up, but I'm not happy about it.
  #17 (permalink)
Old 10-28-2009, 02:59 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Yup, that's the truth of it...!
Welcome Mike! Glad to see you found you way down here to us...
I still haven't had a chance to get to the wrecking yard to check for a factory linkage that will work for you. This is what I was looking for that day in Woodland:
Amazon.com: Mr. Gasket 3811G Ball Joint Quick Disconnect Carburetor Linkage Component-Two Per Set: Automotive
It would require removing the balls that are on the carb and throttle now and then simply cutting a piece of all-thread to length and installing it all. Not too bad a job, but if we can find one that will fit the linkage balls that are already on there, it's even easier...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #18 (permalink)
Old 10-28-2009, 10:54 PM
micklskot's Avatar
micklskot micklskot is offline
micklskot is starting off with a positive reputation.
Dan,
Just got back to Marysville after a trip to NM.
Thanks for keeping my linkage issue in mind. The setup you helped me with is working good. I'll see if I can keep looking around the area, too. I know a guy that works at the local parts store here who has had a few old ford trucks. I'll see if he can help me look around, too, for the linkage that will fit.
I sent you a PM about the sending unit.
Mike
  #19 (permalink)
Old 10-30-2009, 02:01 AM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE. 95_Dually is gaining momentum as a positive member of FTE.
Welcome to the group and to California.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
