Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 10:45 PM
klemklubfoot klemklubfoot is offline
klemklubfoot is starting off with a positive reputation.
reverse roatation gears
hello i have a 1993 f-150 w/ 4.9 and 5sp i am looking to put some new gears in the front axle just so it matches the rear end. The rear end is 3:54 or 3:55 ratio i can't remember but i am looking for a ford part number to order some gears for the front end. I have gone to the dealer inquiring about a new set but they want me to bring the old tag in (which is missing) and if it weren't they'd only know that the original gears are 3:08. So i am wondering if anybody has done this before the rear end had an open diff and I am sure the front is the same. also i am going with ford parts just cause they should not be too noisy when done.
thanks
  #2 (permalink)
Old 10-25-2009, 11:00 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
First, have you confirmed what your front ratio is? Count the turns, pull the cover, whatever? Did you, or a prior owner who told you, change the rear and not the front?
3.08s in a 4x4? Doesn't sound right to me, but that means little.
  #3 (permalink)
Old 10-25-2009, 11:07 PM
yep the rear end had 3:08's i got them changed out a couple of years ago, i was just too cheap at the time to get the front swapped as well. the thing definitely was a highway cruiser,
  #4 (permalink)
Old 10-25-2009, 11:45 PM
Dana 44?
Currie Enterprises Racing Rear End Categories
  #5 (permalink)
Old 10-27-2009, 10:14 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
No such thing as "reverse rotation gears, they are High pinion reverse cut gears.
__________________
'79 F250 13" lift 42" Super Swampers
  #6 (permalink)
Old 10-27-2009, 10:44 AM
Right or wrong, the axles, and in the Currie link, the gear sets, are referred to repeatedly as "reverse rotation".
IIRC you can even find that in the owner's manual where they explain the data codes.
As with many terms, it may or may not accurately describe the exact function of the mechanism.
Tags
44 , data , ford , reverse , rotation
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
