Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 10:38 PM
dakota-boy dakota-boy is offline
dakota-boy is starting off with a positive reputation.
Hard starting problem
When i try to start my truck, alot of times when its cold early in the morning, it will start right up, no problems. When it is hot, or if its even kind of warm, lately it wont start unless i put the pedal to the WOT position. From what i have read, the WOT position kills the injector fire until you let off the pedal. If i do that, it will start just fine. Occasionally, once i do get it started, it will idle real weird, like i have a big cam in the truck, and if i give it any gas it will almost die. After about 10-15 seconds, it runs fine. Any ideas what could be happening? I still drive the truck and it runs fine besides getting about 10mpg, i think it used to get about 13-14 when i first started driving the truck, i have done all tuneup items on it, and it seemed to run alot better once i replaced the o2 sensor, overall the truck runs just fine. Anybody have any ideas why its hard to start?
  #2 (permalink)
Old 10-25-2009, 11:29 PM
4bars13stars's Avatar
4bars13stars 4bars13stars is offline
4bars13stars is starting off with a positive reputation.
im not sure what engine you have in the pickup.. but one possibility is a leaking injector or 2.. that could explain the hard start after it has been driven.. and the loss of fuel mileage..
more info about the engine and year would be a great help...
  #3 (permalink)
Old 10-26-2009, 12:36 AM
saskcowboy saskcowboy is offline
saskcowboy is starting off with a positive reputation.
if it is a 6.0L it could be the FICM.
  #4 (permalink)
Old 10-26-2009, 06:49 PM
my bad! if forgot that part.
the truck is a 1986 302 efi auto 4x4 xlt
  #5 (permalink)
Old 10-26-2009, 07:01 PM
It could be your pick up at the distributor or the dura spark box
  #6 (permalink)
Old 10-26-2009, 08:12 PM
im still leaning towards an injector leaking...it sounds like it is flooding..but it is possible that more than one injector is causing this.. there are other possibilities.. but i think you are looking at a fuel problem more than an electrical one...
  #7 (permalink)
Old 10-26-2009, 09:07 PM
roadrash63's Avatar
roadrash63 roadrash63 is online now
1985 Ford F-150
roadrash63 is starting off with a positive reputation.
me too
same promblems and engine cept an 85
i replaced idle air control valve
cleaned and lubed throttle body
no change...
also if i try to start it and fail .... i turn the key completely off.
it fires right up !
on the second try!
wtf?
__________________
Roadrash63
I'LL KEEP MY GOD,MY GUNS MY FREEDOM AND MY MONEY YOU KEEP "THE CHANGE"!!
saved since 83-shellback 87 usn
ford lover since79
1985 ford f150 4x4 302 fi t-19
2000 ford ranger 4x4 3.0 flex fuel
  #8 (permalink)
Old 10-26-2009, 11:14 PM
I have some new developments on the truck. I went to the auto parts store, got a bottle of injector cleaner for each gas tank and poured it in. After that, i got a gauge to see what kind of fuel pressure the truck was putting out. I suspected a injector leaking, but after about 10-15 min, the truck still had the same fuel pressure as what it had when i just shut it off, so that ruled out the leaky/stuck injector. Then i started the engine and checked the pressure, it goes up with rpms, and back down at idle, it stays between 30-40 all the time, so i think that's good where its supposed to be. Next i took a can of seafoam and ran it into the vacuum line for the brake booster, and let it idle for a while. I immediately noticed a difference in the engine! It was much more responsive, felt like it had alot more power, and just overall runs better. I killed the engine and started it up with different times inbetween, (30 sec, 1 min, 5 min, and 10 min) and each time, it started up on the first try, i didnt have to hold down the gas pedal like i used to for it to start. we will see how it does tomorrow and throughout the week. I think my other problem is that the thermostat is stuck open, the engine never gets very hot, so i believe its dumping extra fuel in since the engine hardly ever gets above 150ish at most. I'll report back once i change out the thermostat this weekend.
  #9 (permalink)
Old 10-27-2009, 06:30 AM
roadrash63's Avatar
1985 Ford F-150
ok
ill try it1
__________________
Roadrash63
ford lover since79
  #10 (permalink)
Old 10-27-2009, 08:41 AM
good to hear that you are not going to have to chase down a bad injector.. one other thing that just popped into my head would be the i.a.c.(idle air controller).. could be sticking shut when the engine is warm.. only thing i have ever ran into to see that happen was chevy.. never had an i.a.c. problem on a ford yet..
  #11 (permalink)
Old 10-27-2009, 07:29 PM
Quote:
it idles high still, and it didnt fix the starting problem, but overall the truck does run better. I am still trying to figure out what the problem is to why it wont start easily. today im back to having to hit the gas to the floor to get it to start. Any ideas? It does idle high, about 1100 rpms in neutral/park and about 1000 in drive. Any helping ideas?
  #12 (permalink)
Old 10-28-2009, 12:50 AM
im honestly running out of ideas.. it wouldnt be a tps problem.. at least i wouldnt think it would be.. this is mind boggling.. if i remember correctly you can adjust your idle up at the throttle body with an allen wrench.. you may try to reset your idle and see what happens.. at worst you would only have to turn it back up.. at best it would help.. might give it a try...
it would be nice if someone else had ran across this problem and found the cure.. ill try and check with my "go to guy" tomorrow.. he has been great with helping me with problems i havnt found an answer to.. he dose alot more auto work than i do..
  #13 (permalink)
Old 10-28-2009, 09:10 AM
bashby's Avatar
bashby bashby is offline
bashby is gaining momentum as a positive member of FTE.
could be a vacuum leak
__________________
86 F350 2WD Duallie dump. 351W edelbrock cam, carb, d/p intake,C6, D0OE heads. 4.10 gears
  #14 (permalink)
Old 10-28-2009, 07:55 PM
roadrash63's Avatar
1985 Ford F-150
when mine was idling high...
i checked and the butterflies werent closing on the intake
so i lubed them and bent the heavy gage wire that goes from them to the throttle cable mount you will have to remove it
see my previous post asking what is this?
__________________
Roadrash63
ford lover since79
  #15 (permalink)
Old 10-29-2009, 08:43 PM
could be the setting on your kick down cable for the transmission that connects to the throttle body. Try unhooking it and see if that works.or try a different throttle body
Tags
20 , ford , hard , start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
