Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-30-2009, 12:46 PM
saskcowboy saskcowboy is offline
saskcowboy is starting off with a positive reputation.
I was taalking with some of the tecs i work with and check the idle air bypass. He was saying that when he worked for Ford they had to replace a bunch of them
  #17 (permalink)
Old 10-30-2009, 10:25 PM
budford's Avatar
budford budford is offline
1995 Ford F-150
My Garage
budford is starting off with a positive reputation.
I had the same problem in my '95 (slightly newer yes, but similar system). I tried vacuum lines, throttle position sensor, all of the usual. It always ran at about 1k rpm's no matter what I tried. Then I had the idle air control replaced and that fixed it completely.
  #18 (permalink)
Old 10-31-2009, 11:09 AM
dakota-boy dakota-boy is offline
dakota-boy is starting off with a positive reputation.
well i have some updates. I have replaced the tps, iac, and changed out the in line fuel filter. What is the fuel pressure supposed to be at? It is in the lower 30's at idle, and it is the upper 30's when revved up, if the vacuum line is unhooked, it jumps up to about 42ish psi. Is that where its supposed to be or do i need to replace that too? I found my thermostat stuck open, so i put in a new 192 deg t-stat, and completely flushed out the system, and refilled it with about 40/60 antifreeze/distilled water mix. seems to be running good now, but let me know what the fuel pressure is supposed to be. thanks!
  #19 (permalink)
Old 11-18-2009, 08:50 PM
so anybody know what the fuel pressure should be? it does not do the weird starting thing and almost die anymore, and im getting better fuel mileage, before the t-stat was stuck open and was running rich. now it is running alot better, lot better mileage but it is still hard to start when its hot and i still have to do the clear flood mode to get it to start. any ideas?
Tags
20 , ford , hard , start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
