can't get my tire off!!!!! - Ford Truck Enthusiasts Forums
Old 10-25-2009, 09:33 PM
bcarless bcarless is offline
bcarless is starting off with a positive reputation.
my rim is stuck. I can't break it loose. it's a steel rim and the truck had been sitting for a while. Now the caliper is giving me problems and the sob won't come off. any suggestions?
Old 10-25-2009, 09:41 PM
symonds86's Avatar
symonds86 symonds86 is offline
symonds86 is starting off with a positive reputation.
BFH, works for me
Old 10-25-2009, 09:43 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Loosen the lugnuts till they have about 1/8 gap behind them, and then run it up and down the driveway, turning and running sideways up a hill or ditch if you have to, till it breaks loose.
Old 10-25-2009, 09:45 PM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
Bang on the rim with a hammer from the inside turn the tire 90 deg. bang on rim turn 90 deg. most likely stuck on centering hole.Be sure and block the truck so it don't fall on you..
Old 10-25-2009, 09:52 PM
Thanks guys. I thought of all these. It was too late for the big hammer. And I was a little gun shy of driving it to break it loose. I just wanted some other opinions.
Old 10-25-2009, 09:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
I like the loosen nuts and drive it around a bit better.
A good spray with PB Blaster around the hub may also help.
Hammer can cause bent wheels.
Old 10-25-2009, 10:16 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
i worked at a tire place years ago.when we ran into this problem,we used a heavy maul.-pounding outward.
it doesnt take much.just keep thumping,and spinning the tire till it brakes free,mind you,thats beating on the rubber.for the stubborn ones,we had no choice but to smack the rim.when we placed them on the balancer we never saw that we hurt them.but we took care to keep rotating the rim,not just pounding in a couple spots.
not saying if it was right or wrong.just what we did.
Old 10-25-2009, 10:28 PM
joe f350 joe f350 is offline
joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.
drive it them losse them them drive it in the driveway back and fourth
Old 10-26-2009, 11:40 AM
Kleenax Kleenax is offline
Kleenax is starting off with a positive reputation.
Stuck wheels
Back in the 70's, I worked at a company that made 35% of all the wheels & brakes in the US (Motor Wheel Corp). I think it was 1976, we had a recall on ALL Monte Carlo wheels because manufacturing "forgot" to size the hub-hole on about 100,000 wheels, and just about ALL 1976 Monte Carlos couldn't get their wheels off!
We had another recall because lugnuts were actually being drawn THRU the wheels if you used an air impact, but that's another story! This is the same company that invented the run-flat wheels for the HumVee.
Old 10-26-2009, 12:06 PM
tlk50's Avatar
tlk50 tlk50 is offline
tlk50 is gaining momentum as a positive member of FTE.
Franklin2 got it right! Loosen the lug nuts a little and drive it in a circle (slowly), it'll pop loose! The BFH method just messes up the rim (plus your knuckles) if your not careful.
Old 10-26-2009, 01:46 PM
Red Cobra's Avatar
Red Cobra Red Cobra is offline
Red Cobra is starting off with a positive reputation.
wow i have never had one stuck more than just having to give it a kick to get it off
Old 10-26-2009, 07:44 PM
Some of the newer trucks with aluminum wheels, 99 to 03 of I remember right had that problem bad.
The center of the wheel would get a little oxidation where it came up on the hub center, pain in the rear to get off.
Old 10-26-2009, 10:42 PM
symonds86's Avatar
yea those trucks daves talking about are horrible for this, even worse on some of the duallys of that year that i see. sometimes takes 3 times longer the get the wheel off then it does to change, balance, and reinstall new tires
Old 10-26-2009, 10:53 PM
Problem solved. I loosened the lugs and drove it. This caliper is fixed. Tomorrow I'll be working on the return lines and the injectors.
Old 06-24-2014, 08:35 PM
Widelens Widelens is offline
Widelens is starting off with a positive reputation.
This site is awesome
Was having some issues getting my wheels off. Popped in for advice & was educated in no time. Can't say thanks enough guys. That loose lug tip worked like a darn Thanks All..
Fake chrome rims slavkonis 1997-2006 Expedition & Navigator 2 12-21-2015 04:23 PM
Rim (wheel) 51 versus 56 f100 1957 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-19-2015 07:32 PM
looking for rims for my 1966 F350 (replace the split rims) Christopher Layton 1961 - 1966 F-100 & Larger F-Series Trucks 17 11-16-2015 11:52 AM
F450 2013 8 lug 17" rims want 19.5x6 rims Rebeccajankovich 1999 to 2016 Super Duty 2 04-28-2015 08:17 AM
F350 tires SavO49 1999 to 2016 Super Duty 2 07-04-2014 07:52 PM
Tags
enthusiast, f150, f350, ford, front, king, problems, ranch, rim, rims, stuck, tire, tires, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
