If by some miracle I got a new job soon I'll be saving up to make an offer on a uni I know of that's just sitting on a farm. (I'll probably offer 500 or so and see what happens) but, I like the 65-66 umm...word i'm looking for... the nicer things on the 65-66, such as the steering column location, the ease of updating to disc brakes and so on. So here's my question, could you put a unibody on the 65-66 frame and basically make it have all those things that make the 65-66s desirable? or do I just live with the old style stuff?
Anyone can make anythiong work if they're willing to fabricate. The frames are not similar between the two. It surely would not be a bolt on affair. I have a 62 and a 66 and like them both. It's not impossible to upgrade the pre 65 models, just a little more challenging since you can't just bolt in 73-79 parts like the 65-up models. Disc brake conversions and engine swap kits are available aftermarket however so not all is lost.
If you are thinking of a chassis swap, why don't you look at a truck that has everything that you want in the running gear and graft the sheet metal on that. Don't swap a chassis and then have to upgrade it.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
61 has the FORD in the grill and 62 does not, same as the Mercury,I know cause I have both.
1961 has F O R D in the center of the grille, 1962 has an elongated star in the same location.
1963 is different, as is 1964, 1965, 1966.
But all the above will fit 1961/66. But the parking lights have to be relocated on some, as they are in the grilles 1961/64, in the upper grille panel 1965/66.
1961/63's have different wheelbases than 1964/66's.
__________________ Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
