Well, I don't know about the newer PCM's. The MAF may be calibrated to the PCM, not the injector size.
I would think that if they are calibrated together (MAF to 42LB injectors) then 8 should be the same as 10. The PCM still uses the airflow thru the MAF to make calculations in either case.
I think this makes sense?
