There are several different types of "brake cleaner". The good ones are an alcohol based (very similar to isopropyl) and is the type I use at work all the time. These are highly flammable and burns clear but won't give off any poisonous fumes.
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
Not a hoax. I used some of the older stuff too close to kerosene heater before. If you get anywhere near an open flame the fumes are wicked. Some of the 3M spray glues give a similar unpleasant result. Caution needed with anything that is chlorinated.
__________________
'fenders
53 F100
"All Ford" Volare Truck
Definitely no joke. I had an experience similar to 'fenders. I built a new engine for my Falcon early last spring and used chlorinated brake parts cleaner to clean the block before final assembly. I was running a kerosene torpedo heater and after awhile the chlorine fumes were getting pretty strong. I was almost done for the night, so I pushed on a little longer before I quit. Hey, I never said I was very smart! I had a splitting headache for two days afterwards and everything in the shop that was bare metal had rusted. I won't even touch a can of the stuff anymore. Go for the non-chlorinated.
__________________
Let's agree to respect each others views, no matter how wrong yours may be.
I was hoping somebody else would confess. I literally crawled out of the garage unable to breath. Puked in a snow bank for awhile. When I felt a little better i walked back and looked into the garage windows. I could see the fumes drifting over and cooking off over the space heater. It was much worse than the CS chambers I have had the "pleasure" of entering in the military.
__________________
'fenders
53 F100
Older airconditioners and refig units do the same thing (Houses, buildings on fire)
Phosgine was one of the main gases used in WWI
I found some in Iraq after they and Iran stopped peeing in each others boots - It was a U.N. thing.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1997 Ford Explorer http://www.4TL8Ford.com
Signature Mod Test
Luckily, my episode wasn't quite that bad, but I'll never try to clean off a running engine with the stuff ever again. I emptied half of my new fire extinguisher on the baby! That extinguisher powder sure is a pain to get rid of
It was the combination of argon shield gas, used in mig and tig welding, the heat produced and the brake cleaner that can produce phosgene gas. There are times when I need to degrease something before welding. If I used the brake cleaner I have on the shelf to clean the part and some is left in a crack it could be vaporized from the welding heat, mix with the argon shield gas and bingo! One snort of that could ruin the rest of your life. Im glad I did not learn that the hard way. Also, I believe running freon through an engine sends mustard gas out the tail pipe.
Phosgene is classified as a Choking Agent as it interferes with the transfer of oxygen to the blood.
There are a whole bunch of common chemicals that turn deadly when combined with other common elements.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
Signature Mod Test
...sorry about that......just don't want to see anyone get hurt.
I guess "sometimes" that kind of stuff just irks me...
FWIW...welding shops DO sell some really EASY spray clerners that
wash-up easly with BASIC soap and water...I think HF has it also...
Not a thing wrong with your post. Say it with some passion and you get my attention. There are too many guys like me that are numb to the warning labels. Every aerosol can in my garage has a warning on it. Ventilation yada, yada. But it gets cold where most of us live. I'm guessing a lot of us spray paint valve covers and such, only cracking the door open. I had no idea brakeclean would put me on my knees with a space heater 20 feet away.
I bet a lot of people here don't realize interior spray glue is almost as wicked. I sure didn't know refrigerant was deadly. Thanks for the heads up. I guess I'll stop sniffing it from now on.
__________________
'fenders
53 F100
A lot of campers, trailers and motor homes use some very toxic refrigerants. I forget what it is called, but is very toxic. The really bad part is that campers, trailers and such are a really confined space. A relative of mine was out camping with their new motor home. They were out for a few hours. When they returned to there motor home, they were hit with a very high concentration of toxic refrigerant. Within seconds, they received chemical burns to the mouth, throat, and lungs. If it wasn't for some fast acting friends, that would have been the end. It took about 2 years for them to recover. The RV manufacturer and refrigerator manufacturer paid off a few lawyers and that was that. That type of refrigerant is still widely used in RVs, camper, trailers, ect.
