Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-28-2009, 01:51 AM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is online now
HT32BSX115 is starting off with a positive reputation.
Quote:
Originally Posted by brucelee View Post
So this is why I was told NOT to weld galvanized pipe. :-X Something about drinking milk afterwords?
It's actually ok to weld galvanized steel. Phosgene gas doesn't come from Zinc.
There's no Zn in phosgene. Zn is an element. (Phosgene: CCl2O)
http://www.sperkoengineering.com/htm...Galvanized.pdf
Phosgene - Wikipedia, the free encyclopedia
From Wikipedia:
Quote:
. Chlorinated compounds used to remove oils from metals may also react under the UV created during arc welding to produce phosgene.
Arc welding produces VERY intense UV radiation. (Intense enough to cause severe "sun" burn very quickly)
The answer is: DO NOT use chlorinated cleaners around ANY arc welding operations EVER!
Most all the "Brake" cleaners that are non-flammable are chlorinated. Some of them are made with naptha (gasoline) but then they have their own warnings..... (BOOM!!)
Cheers,
Rick
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #17 (permalink)
Old 10-28-2009, 06:00 AM
brucelee's Avatar
brucelee brucelee is offline
brucelee is starting off with a positive reputation.
From Wikipedia: Arc welding produces VERY intense UV radiation. (Intense enough to cause severe "sun" burn very quickly)
Cheers,
Rick
Looks like all kinds of brake cleaner has some hazards however, so does skipping the cleaner and using shop air to clean brake drums etc. I also read it isn't wise to let the waste from cleaning brake parts (using spray) hit the shop floor as once it dries the asbestos (if using that type pad) can become airborne. Better to use an absorbent pad.
__________________
1956 Bruce Lee
  #18 (permalink)
Old 10-28-2009, 12:21 PM
rockher_man's Avatar
rockher_man rockher_man is offline
1956 Ford F-100
rockher_man is starting off with a positive reputation.
Lightbulb Wrong!...
Quote:
Originally Posted by ht32bsx115 View Post
it's actually ok to weld galvanized steel. Phosgene gas doesn't come from zinc.
There's no zn in phosgene. Zn is an element. (phosgene: Ccl2o)
http://www.sperkoengineering.com/htm...galvanized.pdf
phosgene - wikipedia, the free encyclopedia
from wikipedia: Arc welding produces very intense uv radiation. (intense enough to cause severe "sun" burn very quickly)
the answer is: Do not use chlorinated cleaners around any arc welding operations ever!
Most all the "brake" cleaners that are non-flammable are chlorinated. Some of them are made with naptha (gasoline) but then they have their own warnings..... (boom!!)
cheers,
rick
I never said Phosgene gas comes from zinc...it is a resultant
from...applying a open flame to galvanized steel...
American National Standard ANSI Z49.1
http://files.aws.org/technical/facts/Z49.1-2005-all.pdf
START at section 5.5.2 & move on from there and you will see...
It is NOT safe to apply an open flame to galvanized steel!
Maybe this will save someone some heartache...
...or headache...
__________________
Gimme Fuel...Gimme Fire...Gimme that which I desire...
Vintage '63-64 Buddy Barr/Holley Triple-Duce...
TOTAL cfm = 730
  #19 (permalink)
Old 10-28-2009, 02:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
ALBUQ F-1 is gaining momentum as a positive member of FTE. ALBUQ F-1 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BlueOvalRage View Post
.... I built a new engine for my Falcon early last spring and used chlorinated brake parts cleaner to clean the block before final assembly. ...
Off on a tangent ... Solvents are no good for cleaning metal in an engine prior to use. They remove the oils but do not float out the particles stuck in pores. Soap and water (a surfactant) is needed. Dawn dish soap and hot water is super for this, but cleans so well you will start to see flash rust almost immediately, so have spray oil ready.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #20 (permalink)
Old 10-28-2009, 04:46 PM
HT32BSX115's Avatar
Well,
That's my point too.....It's NOT a resultant from applying an open flame to galvanized steel.
That PDF doesn't say that either.
Quote:
It does say the following,
I am just trying to point out that Zinc is not related to Phosgene....NOR does it produce Phosgene.
Chlorinated Hydrocarbons COMMON to *some* over-the-counter automotive cleaners when exposed to the UV produced by electric arc welding, DO produce Phosgene.
That's what happened to the person that wrote that original article..............
.A gas welding or cutting flame or the melted metal puddle might also produce enough UV (I'm not going to test it though) But it's not due to the zinc on the metal.
This is probably a moot point because regardless, we need to ENSURE that we have good ventilation and the movement of air MUST be away from the person doing the welding....as instructed in that excellent article you posted.
__________________
  #21 (permalink)
Old 10-28-2009, 06:21 PM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders is starting off with a positive reputation.
"This is probably a moot point because regardless, we need to ENSURE that we have good ventilation and the movement of air MUST be away from the person doing the welding....as instructed in that excellent article you posted."
That really is the point, and can we add that there are a lot of aerosol products we commonly use that are VERY dangerous in the presence of ANY source or ignition. Welder, garage space heater, water heater, doesn't matter.
Most of us have used spray paint in the presence of flames, and not ventilated quite good enough. If it's a cleaner or an adhesive, I learned the hard way the the potential is there. Are there other high risk products in my garage? Reading the label doesn't mean much. It's all flammable, but what products truly have the high potential of putting you on your knees crawling for the door is what we really need to know.
__________________
'fenders
53 F100
"All Ford" Volare Truck
  #22 (permalink)
Old 10-28-2009, 06:27 PM
HT32BSX115's Avatar
Yeah.....no kidding!!
Who would have even remotely thought that the UV radiation from an regular arc welder could produce mustard gas from what most of would consider a common automotive cleaner?
__________________
  #23 (permalink)
Old 10-28-2009, 07:27 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is gaining momentum as a positive member of FTE. 4tl8ford is gaining momentum as a positive member of FTE.
Hey
Think about this
Most "City Water" contains chlorine - Urine contains ammonia
when chlorinated products come in contact with ammonia chlorine gas is released.
Everyone go tinkle in peace now.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1997 Ford Explorer
http://www.4TL8Ford.com
Signature Mod Test
  #24 (permalink)
Old 10-30-2009, 12:59 PM
1956 Ford F-100
Talking ...he said tinkle...
......at least we are all on the same page...seems we all started out
learning the hard way...
...older & wiser now...
....yes........
PEACE...
__________________
TOTAL cfm = 730
Tags
brake , chlorinated , chlorine , cleaner , cutting , free , galvanized , gas , metal , phosgene , pore , safety , welding , wiki , wikipedia
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
