Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 08:41 PM
crazyeddie's Avatar
crazyeddie crazyeddie is offline
crazyeddie is starting off with a positive reputation.
Recommended Jet Size for 460
I haven't yanked a plug yet to see how my new carb setup is suiting the motor so I'm curious as to what size jets people find favorable for their 460.
I'm currently running #68 jets on the primary side of a Holley 600cfm. I don't know what the secondary plate flows. I'm more worried about the primaries since my foot's rarely in it.
And yeah I know - 600cfm is a little weak for a 460
__________________
People work from sun to sun but a gearhead's work is never done. -An old mechanic's adage
  #2 (permalink)
Old 10-26-2009, 03:39 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
Assuming it's stock, 5500 rpm max and a good ignition/air cleaner/exhaust, I calc the cfm at....659.
Assuming this is all correct, I calc the fuel to be about 9% shy, I would increase the 68's 4.5% to 71's. If you were pulling over 5500 rpm I would then suggest changing out the venturi's to 650/700 cfm spec, but should work pretty well.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #3 (permalink)
Old 10-26-2009, 05:36 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
I ran 72's in mine, but it had headers and a CompCams 268H. Pull a plug, itf they look good, leave it alone.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 10-26-2009, 10:39 PM
crazyeddie's Avatar
Quote:
Alright so it sounds like I should be doing okay with the 68's. I'm still gonna yank a plug and see how she's burning.
Beechkid, the 600cfm is definetly not gonna cut it beyond 5000rpm but I have a steep 3.00 rearend gear plus the motor quits pulling hard after 4500rpm with the stock intake and exhaust.
__________________
  #5 (permalink)
Old 10-27-2009, 12:21 AM
kermmydog's Avatar
kermmydog kermmydog is offline
1986 Ford F-250
kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE.
I run a 4160 Holley 600 CFM on my 460 & I don't see anything weak about a 600 CFM. It depends what you are doing with it. Mine is for towing & the 600 CFM is perfect. I run #62 jets in mine. It came with 64s from Holley & I run in the 4000-5000 ft of elevation so I step DOWN 1 jet size per 2000 ft. Maybe that is why pulling a 10,000 # trailer I can get 7 MPG & 10-11 MPG empty. This is in an 86 F250 4x4. The engine has almost 190,000 miles on it. & has run this same set up for 40,000 miles.
  #6 (permalink)
Old 11-04-2009, 11:21 PM
crazyeddie's Avatar
Quote:
WOW 62's!? I don't know what my elevation is here in MI, but it's definetly not as high as what you have to work with! It's good to hear that a 600cfm isn't getting skimpy though. I just find it hard to believe - the carb came off an '84 Mustang GT with a 302 in it and I put it on a 460 and don't need a jet change? WTF!
I'm not gonna complain about the carb though - it hauls x10 more ass with the Holley vs. the Motorcraft spreadbore!
I yanked a plug today to see what I'm working with. Looks lean to me - what do you think? Plugs are Boschs btw.
__________________
  #7 (permalink)
Old 11-04-2009, 11:22 PM
crazyeddie's Avatar
Woah... the pic's a little more blurrier than I thought!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
