Fuel Gauge Resistor - Ford Truck Enthusiasts Forums
Fuel Gauge Resistor
Old 10-25-2009, 08:09 PM
fun98 fun98 is offline
fun98 is starting off with a positive reputation.
Fuel Gauge Resistor
I have a '56 f100 and recently installed a new autometer fuel guage. I realize now the guage and sending unit do not match in relation to their ohms operating range. My tank is only 1/3 full but the guage is reading 2/3 full. The guage operates 33 Full/ 240 empty. I know I can buy a new sending unit for $30 bucks to match my guage but I wanted to know if there was another route. Electical is not my strong point but could I use a resister in-line from my sending unit to my guage? Does that make sense? Any assistance or troubleshoot thoughts would be appreciated.
Thanks
Paul
Old 10-25-2009, 10:24 PM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Old 10-26-2009, 01:15 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
There is no simple resistor that will solve your problem. Not only is the actual resistance range of the stock sender different from the aftermarket units, the size of the range is different as well. If you added a resistor, it would only calibrate correctly to one point on the guage. The error would increase the farther away from that one point that you got. Electronics are available that will scale the signal from the sender to match your guage, but the price is prohibitive. Just go buy the correct sender. There are nickels to be saved elsewhere.
Old 10-26-2009, 03:03 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
If the tank is in the cab then the sending unit is easily reached and a new sending unit would be the best solution. However, if you really want to pursue the resistor route then you will need to know the resistance of the sending unit currently in the tank. Resistors in series always ADD, resistance of resistors in parallel is always LESS than the smallest resistor. From what you have stated it sounds as if you have too little resistance in your sending unit...just as BOR stated, knowing how much to add is tricky. You could add 33 ohms and make the guage accurate at the "empty" side but you may find that the "full" side never makes the guage read more than "3/4". A combination of resistors in series and parallel may solve your problem but I can't tell without the sending unit resistances.
Old 10-26-2009, 03:40 PM
Old F1's Avatar
gas gauge info bobbytnm.jpg (
Old 10-26-2009, 09:02 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
I know that if I continue my "Evil Life Style," some day when I die, I'll go to hell and this will be my punishment: Satan will sit me at a computer and every week someone will write in about mixing gas gauges with the tank sending unit that doesn't match; or people will want to know why they can't get there signal lights to work properly after installing a used 1985 Porsche wiring harness in their Bonus Built. And it will happen over and over and over.
Question? How much money are you spending, or going to spend, on your truck to make it run or to restore it?
JUST SPEND THE $30 ON THE RIGHT SENDING UNIT.
Old 10-26-2009, 09:08 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
sometimes, easier said than done
Sam
Old 10-26-2009, 10:16 PM
Old F1's Avatar
And so how do you know that you are not there now? (same difference)
Old 10-26-2009, 10:38 PM
Thanks. I will just buy a new sending unit. It is easy access and will take the time to unscrew six bolts and screw them back in. Appreciate the reality check.
Old 10-27-2009, 02:53 AM
Quote:
Sam
$30? We aren't talking about a reengine here Sam - It's half a tank of gas-6 mornings Latte's at Starbucks!
Old 10-27-2009, 02:56 AM
Quote:
My point exactly, I am - and you know it too!
Idiot Light to Sweep Guage Conversion on a 64 F350 ihcc104 1961 - 1966 F-100 & Larger F-Series Trucks 35 02-27-2015 06:24 PM
Fuel guage problem 89FordDriver 1987 - 1996 F150 & Larger F-Series Trucks 3 12-09-2014 12:06 PM
Temp guage/sending unit questions Thumper47 Ranger & B-Series 9 03-27-2013 05:51 PM
fuel guage sending unit ohm rating? claymore_mo 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-14-2007 09:24 PM
Transmission temp sending unit priv8pilot 1999 - 2003 7.3L Power Stroke Diesel 5 07-20-2006 11:36 AM
Tags
1955, 1999, 56, adding, f150, ford, fuel, gage, gauge, guage, ohm, ohms, ranger, readings, resistor, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
