Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 07:37 PM
Flightsimmer Flightsimmer is offline
Flightsimmer is starting off with a positive reputation.
Overdrive/3rd gear shift problem
I have been having a problem with "downshifting" into 3rd gear with the "overdrive" button located on the gear shift lever. Particularly when the oil temps have cooled down over night. It is very bad now that the colder weather is here. I have a Banks "Stinger Plus" turbo kit and their "PAC" brake installed. This shifting issue has cropped up in the last year approximately and has gotten to the point that pulling our 32ft 5th wheel is kinda tricky . Specifically when downshifting is needed on a hill or coming to a stop at an intersection as engaging the brake is discouraged while in "OD". With temp. being the issue I wondered if it was in the transmission fluid. Truck has about 128,000 miles. I replaced the transmission fluids at 105,000 miles. Sometimes if the button is held "in" and the shift lever wiggled the light indicating the downshift has occurred will blink intermittently.Eventually as things"warm" up it will stay engaged. '99 F-250 Power-stroke/diesel, auto trans.
  #2 (permalink)
Old 10-25-2009, 08:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
I think you are saying when you press the OD OFF button it does not always turn off the overdrive. I'm not sure that's what you're asking.....
If that is your problem, start by removing the plastic cover from the steering column. Carefully inspect the wires where they enter the shifter handle. They are probably rubbed through or broken inside the insulation. Either fix the wires or get a new shifter handle for about $50.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
Tags
3rd , button , f150 , fix , ford , gear , gearshift , overdrive , problems , shifter , shifting , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
