Wheel lug nut torque? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-25-2009, 06:41 PM
varmintjager varmintjager is offline
varmintjager is starting off with a positive reputation.
I just had new tires put on my 2004 F-250 and on the bill I had to sign that I would retorque the lug nuts after 30 miles. The bill states that they torque to 115 foot pounds. In my Haynes manual for the Ford Super Duty it recommends 155 foot pounds torque for 2003 and newer Super Dutys. What is the correct torque number? The mechanic that installed my wheels says 140 foot pounds max. and 115 to 120 foot pounds that they use.I have been using the 155 FP number when I rotate the tires once a year,never had any trouble.
Old 10-25-2009, 06:45 PM
trackspeeder's Avatar
trackspeeder trackspeeder is offline
trackspeeder is gaining momentum as a positive member of FTE.
165 foot lbs will do it.
Old 10-25-2009, 07:20 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Wow, you better tell that mechanic to take a second and look it up on the tire charts if he sells lots of tires for superduties. 155-165 ft lbs is the correct #.
Old 10-27-2009, 07:05 PM
Thanks guys for the correct touque number. It looks like I will go back to the 155 foot pound torque setting for my wheels. I suspected that he was wrong. This is a great forum.
Rear Wheels Rims Stuck on Truck fightlivefree 1987 - 1996 F150 & Larger F-Series Trucks 16 02-10-2016 05:39 AM
Tire is off-camber!!! Please help! mr.fordneck 1987 - 1996 F150 & Larger F-Series Trucks 10 05-21-2013 09:17 PM
TORQUE VALUE--WHEEL BEARING STUDS Rongold 1999 to 2016 Super Duty 6 01-15-2012 11:23 AM
Anti-seize on lug bolts? DaveMac2Vans Aerostar 13 05-13-2009 11:23 PM
Lug Nut Torque hambone00 Brakes, Steering, Suspension, Tires, & Wheels 5 01-30-2009 02:44 PM
Tags
2003, 2004, duty, f150, f250, f350, f550, ford, lug, lugnut, nut, specification, super, superduty, torque, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
