Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 06:34 PM
doug6644's Avatar
doug6644 doug6644 is offline
doug6644 is starting off with a positive reputation.
More front axle questions
I was nosing around while doing some brake work on my 96 F150. I am going to have to replace the axle joints soon. Will the axles come out of the spindle after removing the spindle shaft? Mine just appears to be a hole the size of the axle shaft, or is it just so rusted in that it looks like the hole is that small? I want a little bit of insight before I tear it apart, or else I may be walking to work till I get it back together.
  #2 (permalink)
Old 10-25-2009, 07:08 PM
doug6644's Avatar
Come on guys, I know someone has replaced axle joints on 96 F150
  #3 (permalink)
Old 10-25-2009, 07:16 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
hi doug.
yes.to replace the front U-joints,once you get everything out of the way,the axle will pull straight through.
don't forget,your going to need a dana 44 axle socket (sold for about $20-$30 or rented out at $15 at most auto parts stores-large socket with 4 tabs) and some new seals.also repack your wheel bearings while your at it,so don't forget to get some grease.
be sure to replace all 3.there is one on the drivers side.and an inner and outer on the passenger side.you don't want to do this again,so do all 3 at once.
good luck.
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #4 (permalink)
Old 10-25-2009, 08:27 PM
doug6644's Avatar
Three?.....WTH..........the parts store only quoted a price on two joints..........are there different axles on 96 150's? Or is there only one option? But anyhow, thanks for the insight, I was looking at the configuration, and there is no way a person could get the axle out otherwise without lots of effort seperating balljoints.
  #5 (permalink)
Old 10-25-2009, 08:40 PM
fatboyf150's Avatar
fatboyf150 fatboyf150 is offline
fatboyf150 is starting off with a positive reputation.
you have to unbolt the spindles from the knuckles to get the the axles through them. also, the pass side axle has a c-clip holding the axle in the ttb carrier.
__________________
FOUR WHEELING - certainly the most fun you will have with your clothes on!!!
2000 ranger 3.0 auto tranny extended cab 4x4 315/70/16 goodyear mtr's
95 f150 351w 3in body lift, 38.5 swampers
coastalcarolinaoffroad com
  #6 (permalink)
Old 10-25-2009, 09:08 PM
donniezyea's Avatar
donniezyea donniezyea is offline
donniezyea is starting off with a positive reputation.
First off i dont have a 96 150, but im pretty dang sure you dont have to mess with ball joints.... Like fatboyf150 said, remove hub and spindle. Left side axil just pulls out, right side you have to separate the carrier from the axle case to access the snapring remove and the "stub shaft" can now be removed. I just read this from the Haynes manual for later model internally retained ifs systems.... My 91&86 are different but this should help you!!!! Its really not that hard!!! Make sure you get the wheel bearings all torqued correctly!!! have more questions ask away!!!!
__________________
-1986 F-150-4 Speed Granny-302 V8-4x4-6" BDS
-1987 F-250 4x4 Auto 351 Parts Truck
-1989 F-150 2x4 Auto 302 Parts Truck
-1991 F-250 4x4 302 Rust Free 5 Speed Manual
-1991 F-150-4x4-4.9 I6-Mazda
-1996 F-250 4x4 351 3.55 5 speed zf
  #7 (permalink)
Old 10-25-2009, 09:21 PM
doug6644's Avatar
So I'm going to have to open the differential also? Guess I better get some lube, and sealant !! I'm curious what the spindle bolts look like, after taking the brakes apart, and all the scaling that was on them, I'm scared to see what it looks like behind the rotors. I have yet to look at the pass. side, but I know the drivers side is bad. How much time should I set aside to tear both sides apart, I am fairly adept at this, but I have yet to have one torn apart, so this will be a learning exp. I have the socket sitting in the toolbox for the axle nut, so no deal there, but I am curious about getting to the c-clip for the pass. side.
  #8 (permalink)
Old 10-25-2009, 09:32 PM
doug6644's Avatar
Oh....now I'm starting to get it, there is an intermediate shaft on the pass. side. So the pass. side has to be seperated from the outer section of the shaft, before the inner section will be able to be removed. Please disregard the comment about opening the diff. huhhuh I'm picturing a rear diff. The carrier is accessible from around the center of the right half of the axle. Like I said I haven't done much looking at the pass. side, I just know there is some serious "popping" from the d-side when engaged.
  #9 (permalink)
Old 10-25-2009, 09:36 PM
doug6644's Avatar
I don't have a manual donniezyea, too tight to go buy one, does your manual state the specs for the w. bearings? I'd hate to spend more than 30$ to rebuild my drivetrain....hehe.
  #10 (permalink)
Old 10-25-2009, 09:50 PM
donniezyea's Avatar
I think you might have to split the diff as the snap ring is holding the stub shaft inside so unless you inner ujoint is BAD BAD id leave it. (id fix it if you already in that far...here are some specs the pass side is a two piece one outer u joint and a rubber boot with spline then ujoint into diff with snap ring. so you can pull the axil from the spline but to get the inner ujoint you gotta split the diff....
Spindle to knuckle 35-40 ftlbs
It looks like you have manual locking hubs (later model dana 44 ifs with manual locking hubs) tighten nut to 70ft lbs while seating bearing. then back off 90 degrees, retighten nut to 15-20 ft lbs. This is what my book says its totaly different from my style so i hope im giving accurate info!!! if someone with a 96 has done this CHIME IN! If you have auto hubs i got those specs too.....
__________________
  #11 (permalink)
Old 10-25-2009, 11:05 PM
doug6644's Avatar
I don't believe the inner is bad, matter of fact, I only hear the d-side, but figured I'd do them both at the same time, then I learned there is an inner. I'll probably just stick to the outers, I'm not too sure about splitting the diff, and besides if it ain't broke(breaking) don't screw with it. Just finding this site has already helped me enough to dive right in and feel comfortable. I have all the tools to do it, including the spindle socket, so with the exception of a hoist, but in reality, how much help is a hoist really gonna be? I've got a creeper seat, and most of it needs to be ground work. So, armed with this knowledge, we'll dive in within the week, thanks for the specs.
  #12 (permalink)
Old 10-25-2009, 11:37 PM
1993 Ford F-250
if you haven't done it before,be prepared to spend the weekend at it lol.
reach under and grab the shaft,see if you can spin it,and watch/feel the u-joints.you know,just like you do from time to time to check the rear drive shaft.
if you dont see/feel any play at all in the pass side.and you say "if it ain't broke,dont fix it"
be prepared to feel this way strongly once your done the drivers side hahaha.
my f250's torn down right now.im doing the same job your doing.already done it before on my 96f150.
just watch where you take out each clip.you need some skinny screw drivers.now,since you dont have a manual.place each part on a self the way they come out.
its a job.and not a fun one lol.
but you have us here on your side to keep you going.so your all set!
you can do it!
__________________
  #13 (permalink)
Old 10-26-2009, 01:13 AM
Ford6.02005's Avatar
Ford6.02005 Ford6.02005 is offline
Ford6.02005 is starting off with a positive reputation.
Quote:
Just wanted to let you know after 10+ years working in a 4x4 specialty shop I found a shortcut to replace the passenger side inner u-joint-I do them with a balljoint/u-joint press without removing the stub axle from the differential. Separate the intermediate axle at the rubber boot so the yoke will swing further to allow retaining clip removal then carefully use the press to drive out the u-joint caps. Be sure to mark the slip yoke splines to assure they are reassembled the same way-both u-joints need to operate on the same plane.Use press to install new u-joint caps.It's a little tricky but it saves a lot of labor if you don't have to remove the 3rd member!
  #14 (permalink)
Old 10-26-2009, 08:02 PM
doug6644's Avatar
Hey Ford 6.0, are u-joint presses smaller than ball-joint presses? I have a ball joint press (OTC brand). Will the axle move far enough to allow the large ball joint press fit around it?
  #15 (permalink)
Old 10-26-2009, 11:39 PM
Same thing-Mine is OTC also.It is tight but it does fit.I've even done Explorers with the Dana 35 TTB this way.
Tags
1987 , 1993 , 4x4 , 91 , 97 , 99 , axle , differential , drive , f150 , f250 , front , nut , popping , remove , torque , ttb , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
