Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 06:24 PM
kenpobuck kenpobuck is offline
kenpobuck is starting off with a positive reputation.
O-rings instaed of headgaskets?
I was talking to a Ford mechanic last nite and he was telling me that people are useing o-rings instead of head gaskets on big power motors nowadays. I guess they are having the heads machined to accept o-rings and bolting the heads to the block metal to metal. Anyone else heard of this? He says it nearly eliminates blow outs. I am not so sure as it wouldn't stop bolts or studs from stretching woud it?
__________________
DON'T BUY IT ..FAB IT!!!!
88 Bronco XLT 6.9 IDI, C6, Dana60 rear, 50 front, 3.55 gears, 33x12.5x16.5's. built by me becuase I just had to!
Kentucky Chapter Member
  #2 (permalink)
Old 10-25-2009, 07:56 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
If you have the money to get your heads and block cut for orings which are normally used on dragsters or HP race cars go for it.
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 10-25-2009, 08:07 PM
archangel archangel is offline
archangel is new and has a neutral reputation at this point.
I don't think it's a rubber O ring, but a grove with an interference fit metal ring.
In the racing circuits the racing O ring heads I am familiar with have what I described above, but it just pinches the head gasket tighter instead of replacing it.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
  #4 (permalink)
Old 10-25-2009, 10:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Still need head gaskets to seal the coolant and oil passages.
Yes the O ring is steel, not rubber.
Last I heard the machine work was around 1500 dollars just for O ring work.
Not that many machine shops have to tools to do the work.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 10-25-2009, 10:58 PM
joe f350's Avatar
joe f350 joe f350 is offline
joe f350 is gaining momentum as a positive member of FTE.
1500 bucks ary they crazy thats worth more them the truck
__________________
85 ford f350 lifted 11 inch 37 6.9 t19 my freinds call it the panzer
  #6 (permalink)
Old 10-26-2009, 06:56 PM
Well at least I know it is true, but I aint paying that lol.
__________________
  #7 (permalink)
Old 10-26-2009, 09:13 PM
1986 Ford F-250
Start talking 40 PSI boost, 18 to 1 compression, nitrous, water injection and hot IP, what is another 1500 for O rings to keep it all together.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #8 (permalink)
Old 10-28-2009, 09:05 PM
Some people have way to much money!
__________________
  #9 (permalink)
Old 10-30-2009, 10:28 PM
Marianna2003 Marianna2003 is online now
Marianna2003 is starting off with a positive reputation.
Dave aren't you running 'O'rings? I was under the impression that they were copper and they would install rubber orings around all of the other passages. I didn't think the heads were grooved at all, just the block. I know that the head gaskets for the old GMC ToroFlow engines were a steel ring cemented into a regular fiber head gasket so that the entire clamping load of the head bolts was on the ring with very little on the other parts of the gasket.
  #10 (permalink)
Old 10-30-2009, 11:19 PM
catfish101's Avatar
catfish101 catfish101 is offline
catfish101 is starting off with a positive reputation.
There are allot of engines like you are describing. VED12 Volvo engines are like that. They have rubber seals at the coolant passages and oil passages. Cat has engines like that. That isn't uncommon. The gasket basically holds the seals in place and acts a shim. The gasket plays another important parts. it shims the head to block which has an influence on the compression ratio. You you take out the gasket and put just sealing rings you would raise your ratio. You don't want that. On some engines if the block or head is machined to a specific points then an oversized head gasket is needed. I have been playing with a 6.9 motor and I have made a spacer to drop the compression ratio. I haven't messed with it in awhile. Been doing other things. Found some different push tubes and was in the middle of working out a different valve train. Solid lifters which needs different rocker arms. They have to be adjustable. It is a shame I don't have all the tools I would like to have or I would have made a direct injection heads for these blocks. Like many other things, this project is put on hold for other things.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #11 (permalink)
Old 10-31-2009, 04:08 AM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is starting off with a positive reputation.
There are guys with Cummins that are fire-ringed running 140 plus pounds of boost. BUT only that high on dyno runs or sled pulls.
__________________
'91.5 Dodge,4WD,Intercooled Cummins;5 Spd.,NP205;D70R,D60F,3:54s
'94 F350,4WD,CrewCab;7.3L IDI Turbo,ZF5;D60F-3:54 374K Straight-piped
'86 F350,2WD,CrewCab,6.9L NA,T19,10.25"4:11
'97 F350,4WD,460,E40D,D60F 3:54, 269K
'97 F250,PowerStroke,4wd,Xcb,E40D,3:55/54,284K Straight-piped
'95 F350,4wd,PowerStroke,CrewCab;D60F 4:10,ServiceTruck,300K,Straight-Piped
  #12 (permalink)
Old 10-31-2009, 01:56 PM
1986 Ford F-250
I looked for copper head gaskets when I built my engine, only found them for the Stroke engines so I went with Fel Pro.
No machine shops around here install O rings, so the cost was out of the question for my build budget.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Tags
12 , 2003 , 73 , cummins , fire , fordtruckscom , gasket , heads , machined , oring , orings , reviews , rings , turbo , valve , ved12 , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
