Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 05:42 PM
rat49f6's Avatar
rat49f6 rat49f6 is online now
1999 Ford F-250
My Garage
rat49f6 is gaining momentum as a positive member of FTE. rat49f6 is gaining momentum as a positive member of FTE.
truck is running odd
ok on thursday made my own oba and disconnected the red line off the turbo. im now aware thats not needed so its back on. last night and all day yesterday the truck ran amazing with the oba i did throw codes earlier in the evening but no running issues.
this morning i checked my oil (habit i do it every morning)and started my truck up and noticed a severe lack of power. im not getting much smoke definetly not as much as normal and very little to no boost.
the truck will runn up to 70 mph on the highway and seems to boost some but the gauge reads zero and no darh vader noises out of it when i let off or shift
so i guess ill list my observations:
much less black smoke
no boost on gauge
turbo 25% as loud as normal
oil is good
red line is back on
air filter is good
i/c boots are on
im thinking maybe i popped the wastegate open and it stuck open ??
__________________
JIM
early 99 F250 super duty ...ext cab...xlt... 7.3 powerstroke...6 speed...'08 8ft bed...
6637 mod ...factory muffler delete...TS Performance 3 position 75/100/140+ extreme chip...6.0 i/c w/ riff raff boots
1949 Ford f6... flathead v8... 4 speed crash box...
10" frame drop... 6" body drop ...work in progress
  #2 (permalink)
Old 10-25-2009, 06:15 PM
big poppa's Avatar
big poppa big poppa is offline
Monitoring The Vitals
2003 Ford F-250
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
I'm almost 99% sure, you need to open you OBA a little bit more, allow the map sensor to see a bit more air flow. When I made mine, thanks to Jim, I preset my regulator too much and the map wasn't reading any boost, so the truck cut out, if you know what I mean. How did you measure the boost output to the map sensor??
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 131,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
  #3 (permalink)
Old 10-25-2009, 06:21 PM
rat49f6's Avatar
1999 Ford F-250
My Garage
yeah i set it at 19. the forney mini reg i bought has the gauge on the front but now i dont remember which way on the knob lets more air in
__________________
JIM
  #4 (permalink)
Old 10-25-2009, 06:23 PM
rat49f6's Avatar
1999 Ford F-250
My Garage
oh and mike it ran like a champ for a whole day after i installed the oba
__________________
JIM
  #5 (permalink)
Old 10-25-2009, 06:36 PM
big poppa's Avatar
2003 Ford F-250
I think clockwise it closes it up Jim, meaning it doesn't let the map see any pressure, counterclockwise, it lets the air flow thru the reg. to the map. Loosen it up a bit and take the truck for a drive, keep testing until your satisfied..
__________________
  #6 (permalink)
Old 10-25-2009, 06:58 PM
rat49f6's Avatar
1999 Ford F-250
My Garage
any reason it would have ran fine for 24 hrs then to day fall on its face
it seriously feels like driving an old IDI with extra fuel to it
__________________
JIM
  #7 (permalink)
Old 10-25-2009, 07:14 PM
big poppa's Avatar
2003 Ford F-250
Maybe the knob rattled loose from the vibrations, just throwing some senarios out there. If the knob is loose, throw a strip of black tape across it after you get it set again and let me know what happens. This is what mine looks like, air compressor regulator.
__________________
  #8 (permalink)
Old 10-25-2009, 07:22 PM
rat49f6's Avatar
1999 Ford F-250
My Garage
thx ill try that
__________________
JIM
  #9 (permalink)
Old 10-25-2009, 07:28 PM
megawatt00's Avatar
megawatt00 megawatt00 is online now
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
Jim did you tighten up on the waste gate rod? It kinda sounds like a boost leak. If you had gauges you could watch your EGT's . When i misaligned my spider mt EGT's were high and my boost was very low
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #10 (permalink)
Old 10-25-2009, 08:06 PM
rat49f6's Avatar
1999 Ford F-250
My Garage
Jim i didnt touch the waste gate rod
I have gauges i can easily hit 1250° on 140 tune now i can barely spike 1000°
__________________
JIM
  #11 (permalink)
Old 10-25-2009, 08:14 PM
megawatt00's Avatar
Try removing the OBA and see if it improves. The no boost on the gauge tells me that there is a boost leak somewhere
__________________
Jim
2001 F350 4X4 DRW
PAA # 14
  #12 (permalink)
Old 10-25-2009, 08:25 PM
big poppa's Avatar
2003 Ford F-250
I agree with Jim, unhook it and re-attach the line to the map sensor and see. I still think its the regulator, same symptoms I had.
__________________
  #13 (permalink)
Old 10-25-2009, 08:37 PM
rat49f6's Avatar
1999 Ford F-250
My Garage
Thats my plan im gonna check for leaks and see where i stand
__________________
JIM
  #14 (permalink)
Old 10-26-2009, 05:11 PM
rat49f6's Avatar
1999 Ford F-250
My Garage
so in the process of taking the oba off i broke the nipple off the map sensor ... soooo now the truck is down till thursday when i can afford a new one
__________________
JIM
  #15 (permalink)
Old 10-26-2009, 07:05 PM
big poppa's Avatar
2003 Ford F-250
O no, couldn't you glue it on in the meantime, its plastic right??
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
