well, we bought a FMC46L from Summit Racing, it is a 2004 4.6/4r70w complete assembly. it came with the ECU, engine harness, fuel pump control, and another piece that looks to me like a fuel pressure control. what do i need to install the returnless fuel system? we are going to get an ECU harness from a 99-04 mustang to complete that side of the wiring but i am unsure what else will be needed.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see.
The fuel pressure control is the transducer on the drivers side fuel rail, little black thing with a connector on it. This communicates withe the FPDM (fuel pump driver module, originally mounted in the trunk of the SN95 cars)
Got any pictures of the part in question?
Just did one of these swaps but we swapped it to a full aeromotive return system with dual A1000 pumps
__________________ God is Great, Beer is good, people are crazy
'06 F250 PSD XLT, CC, SB, 4x4, SCT custom tune from eric, ARP studs, autometer gauges, 4'' MBRP turbo back, AFE stg II, EGR delete, Zoodad, Chrome step bars, '08 mirrors, viper Alarm, Rough Country 8'' Lift, MT MTZ 36-15.50-20, 20X10 Motometals.
just this morning i received a reply from Summit Racing as to what the parts in the box were. they suggested to do the return style conversion.
the motor is stock, so can i use the factory pump from the donor 96 5.0 mountaineer? i am going to get the fuel rails to convert it to the return style system, any recommendations on brand i should be looking into?
also, my dad was over @ the shop yesterday and clued me into what was what, the part i didn't know what was is the purge device(two fuel connectors, one electrical and one vacuum connector)
Reason: forgetfullness
Just get a set of rails off a PRE 99 4.6 Yeah the Mountaineer pump should work. Obviously you will need a custom tune to run it with a return style system. You will also need the tune to turn off the PATS, EVAP and I would recomend EGR.
Just get a set of rails off a PRE 99 4.6 Yeah the Mountaineer pump should work. Obviously you will need a custom tune to run it with a return style system. You will also need the tune to turn off the PATS, EVAP and I would recommend EGR.
do you have a recommendation on someone to do the custom tune? i know the detail zone does that, but i am not familiar with the company.
I have used the detail zone harness and was great, but never their tuning. I always use tru-dyno sports. Tru Dyno Sports LLC Aaron does an amazing job and can get you what you need. Give him a call and tell him what you need.
got a set off a "cash for clunkers" 98 mercury grand marquis from the local pull it yourself salvage yard.... $12.00 .....can't beat that. got them cleaned up and installed
also, just an fyi... the rolling frame is done, engine, trans and rear axle installed...pics are up in the gallery "1949 F1 build"
