Go Back   Ford Truck Enthusiasts Forums > General > General NON-Automotive Conversation
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General NON-Automotive Conversation No Political, Sexual or Religious topics please. SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 03:40 PM
cjben cjben is online now
1995 Ford F-150
cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold
shorter stock for remington 870?
I need a shorter stock for my remington 870 slug gun. I have no neck and short arms.makes it hard to get a good sight picture through the scope. I looked at the youth model stock,but it is only an inch shorter,from what I can figure I need at least 2 inches shorter. I have the scope pulled back as far as it can go on the mount without touching. thanks for any ideas.
__________________
I'LL KEEP MY GOD,MY GUNS MY FREEDOM AND MY MONEY YOU KEEP "THE CHANGE"!!
1995 f150 xlt extended cab flareside 5.0 33" tires 3" body lift
  #2 (permalink)
Old 10-25-2009, 05:48 PM
Old93junk's Avatar
Old93junk Old93junk is online now
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
Any decent gunsmith can cut your stock to fit your needs, he will do a better job than your table saw too. There are adjustable recoil/buttpads available too that allow you to change the pull to suit any shooter, check Cabela's.
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 10-25-2009, 06:23 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Another source:
Hogue Inc., The Best Value In Handgun Grips, Rifle Stocks and Accessories - Bar None!
  #4 (permalink)
Old 10-25-2009, 09:22 PM
Gearbanger 101's Avatar
Gearbanger 101 Gearbanger 101 is online now
Gearbanger 101 is gaining momentum as a positive member of FTE.
I have the Knoxx Spec Ops stock on my 870 Tac 2 and its got all the adjustability anyone could ever need.
You will have to switch over to the "pistol grip" as a result, but a nice benefit is that it has unmatched recoil control.....especially if you're feeding your gun a steady diet of slugs!
Their anti-recoil system is not joke! No more bruised shoulders, or loose fillings. It's so good I can shoot 3" slugs through my Tac 2 holding it with one arm.....with ease.
.....(not that I normally do that sort of thing, but just for demonstrative puproses)
__________________
~Brian~
  #5 (permalink)
Old 10-26-2009, 08:07 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger 00BlueOvalRanger is offline
00BlueOvalRanger is a splendid one to behold 00BlueOvalRanger is a splendid one to behold 00BlueOvalRanger is a splendid one to behold 00BlueOvalRanger is a splendid one to behold 00BlueOvalRanger is a splendid one to behold 00BlueOvalRanger is a splendid one to behold 00BlueOvalRanger is a splendid one to behold
I totally agree with both posts!!!!!
Take it from someone that has been down that road.
Measure twice (no, THREE times) and cut once!!!!
My son, Brad, needed a shorter stock and I decided to cut down the stock of his 870. (Please note: I've cut several stocks, and nothing beats a table saw, like a good 'jig'! Once you mess up that buttstock, it's done. Let a QUALIFIED gunsmith cut the stock!!!)
I cut down a 'beater stock' that I picked up at a gunshow, and cut that one, leaving the factory stock. . . . original. When I cut that stock, his LOP was less than 10"!!!! I then fitted a softer recoil pad to it.
He's since outgrown that 'munchkin stock' and is using a little longer stock, with a Limbsaver® pad on it.
As for the SpecOps stock......... absolutely incredible stock!!!!!!!!
I put that on my oldest daughter's 870 that I set up for her. She had never fired a shotgun, until I gave her this one.
She shot box after box of 00B and Slugs with NO ill effects.
  #6 (permalink)
Old 10-26-2009, 12:14 PM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
Wow, what timing! I just bought a 870 myself, took it home to show the wife how to shoot it and she couldn't shoulder it. Her idea was to just shoot it from waist level at whatever is coming through the door without sighting it. Thanks for the link!
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #7 (permalink)
Old 10-26-2009, 12:30 PM
therifleman556's Avatar
therifleman556 therifleman556 is offline
Ah... Good Ole Slabsides
therifleman556 is gaining momentum as a positive member of FTE.
It wouldn't be difficult if your good with tools and detail oriented to do what the gunsmith does yourself. Its easiest if you have some type of edging tool but a steady hand can manage. Using the tool or your steady hand draw a line parallel to the end of the buttstock (not the pad) however shorter you want the stock to be. Once the line is in place you lay masking tape along the line (its easier to see than the line itself and its more durable). Using whatever saw you have around (bandsaw would be ideal but even a handsaw or coping saw will work) cut the excess off leaving around 1/16" left between the cut and the line. Once the cut is made sand the stock down to the line (make sure you use a sanding block otherwise it'll look like hell). Start using a coarse grit to mow through the majority of the work and switch to fine once you get close to your line. You'll probably have to find a new buttpad, and the holes may need to be relocated to screw it on. Simple and cheap. Any questions just ask. Unless the stock in question is synthetic, if thats the case I think I just wasted ten minutes of typing
__________________
2nd Amendment: protector of the rest!!!
2002 Dakota 4.7L-demoted-108k miles
1992 F-350 4X4 7.3L IDI E4OD 4:10LS -124k miles daily driver
1978 F-150 4X4 4spd 351 Holley 600/Edelbrock P-400 (work in progress)
  #8 (permalink)
Old 10-26-2009, 07:24 PM
1995 Ford F-150
Quote:
sorry forgot to mention my stock is synthetic. I am looking into the the knoxx spec ops stock,that looks like it would fit the bill,have to make sure it is legal here in the anti-gun state of il.
__________________
  #9 (permalink)
Old 10-29-2009, 09:25 AM
Frdbuy8589 Frdbuy8589 is online now
Frdbuy8589 is starting off with a positive reputation.
2nd on the knoxx recoil stock. Its nice because your not locked into 2 setting. I found that I like to lengthen the stock in the summer and then come winter time with all the insulated clothing I can shorten it and still handle it
Tags
870 , aim , anti , arms , changing , daughters , gun , hard , hogue , loose , recoil , remington , short , specops , stock , youth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
