Remove and Replace Radiator - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-25-2009, 02:46 PM
gvrangr98 gvrangr98 is offline
gvrangr98 is starting off with a positive reputation.
Question Remove and Replace Radiator
I am about to R&R the Radiator in my 3.0L Ranger Automatic Trans 4X4.
Any thing I should be aware of? It seems pretty straight forward to me; only the trannie cooler lines seem very corroded. Anyone have any tips on how to proceed? Thanks in advance.
Old 10-25-2009, 03:40 PM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
I always use line wrenches so as not to damage fittings. Know where you can quickly obtain cooler lines in case they get damaged.
Old 10-25-2009, 03:57 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Why are you removing the Radiator?
I have two tranny coolers on my 1999 Ranger with 4R44E Transmission, so there was some extra fluid coming out of the lines when I took them loose.
Long Haul with a Ranger? SSBB 1987 - 1996 F150 & Larger F-Series Trucks 9 06-26-2014 06:49 PM
Super Cooling / Camper Special radiators JIMMYZZ28 Cooling, Heating, Ventilation & A/C 1 05-29-2014 01:07 AM
radiator support removal? msauls 1957 - 1960 F100 & Larger F-Series Trucks 6 02-05-2013 07:18 PM
Ford Ranger 4.0 water temp sending unit r4m Cooling, Heating, Ventilation & A/C 0 06-10-2011 10:00 PM
84 Bronco II runs hot McStein Bronco II 7 11-08-2010 10:16 PM
Tags
07, 150, 1997, 2000, change, changing, f150, ford, lines, radiator, ranger, remove, removing, remve, replace, tranny, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
