Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-25-2009, 01:54 PM
isenegger's Avatar
isenegger isenegger is offline
isenegger is starting off with a positive reputation.
help wiring up push start button and ign switch
i just got this 88 f150 4spd. the PO broke the ign rod in the column. so he screwed the ign switch to the bottom of the dash and you have to slide it to start it and turn it off. i want to put a push button to start it and a toggle switch to turn on the accessories and use it to turn the truck off. anyone got a diagram or info on how to do this? thanks!
__________________
2002 Ford F150 Sport 4.2 5spd,
1988 Ford F150 4x4 4.9 4spd, 39.5" boggers
  #2 (permalink)
Old 10-25-2009, 07:13 PM
isenegger's Avatar
im trying to bypass this switch and use toggle switch and push button to start and run truck.
__________________
  #3 (permalink)
Old 10-25-2009, 10:19 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
I don't have a detailed diagram of a 88 switch, but I do for a 86, and it will take a double pole momentary pushbutton switch for the starting function, and one double pole single throw switch for the run, or two single pole single pole switches.
In 86 the power comes in on two large yellow wires.
The momentary start switch should have 4 terminals. Two will be shorted together and hooked to the yellow wires, and one of the other terminals will be hooked to a red/blue(start) and the other terminal will hook to a brown/pink(resistor bypass).
The toggle switch will have 4 terminals also. Two will be shorted together and hooked to the yellow wires. One of the other terminals will connect to the red/lightgreen(ignition and other stuff). The other terminal will hook to the black/lightgreen(accessories)
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 10-25-2009, 11:18 PM
isenegger's Avatar
i came up with this. i think it might work.
im using a universal switch like this
and wiring it up like so
__________________
  #5 (permalink)
Old 10-26-2009, 01:11 PM
isenegger's Avatar
anyone think this would work
__________________
  #6 (permalink)
Old 10-26-2009, 02:57 PM
Franklin2's Avatar
I doubt that will work. Usually you cannot tie all those wires together(for example the red ones in your diagram). That's the reason they have so many sections to the original switch. You are also tying the blue wires together in your diagram also.
I predict if you hook it up like your diagram, the starter may not stop and or the engine will not turn off when the key is in the off position.
__________________
Dave F
  #7 (permalink)
Old 10-26-2009, 05:53 PM
isenegger's Avatar
i changed a few things. how about this way?
__________________
  #8 (permalink)
Old 10-27-2009, 10:14 AM
Franklin2's Avatar
You are still tying wires together. You need to keep them separated like the factory had them. I recommend the easiest solution would be to repair the steering column and put the factory switch back on. If you insist on switches, you will need several to duplicate the factory switch and it's function.
__________________
Dave F
  #9 (permalink)
Old 10-27-2009, 08:38 PM
isenegger's Avatar
well i gave it a shot and it worked flawlessly...the second picture i posted is how i wired it. everything works like it should. the only think i noticed is that the clutch does not have to be pressed down to start anymore. i was going to bypass that anyway. we learn something every day.
__________________
Tags
150 , 1989 , 89 , button , bypass , diagram , f150 , f250 , ford , push , put , start , starter , switch , toggle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
