How to dissemble/reassemble a modular connector.
Old 11-11-2022, 01:42 PM
BRIANSC6's Avatar
BRIANSC6
BRIANSC6 is offline
Trailering
Does anyone know how to disassemble this connector. It is the connector that goes into the optional trailer camera for late mode Superduty’s. I am going to install this camera on my 5th wheel and it will pass thru a junction box and cable gland on the roof of my 5th wheel trailer.
To get a cable gland with a large enough opening to allow the connector to pass thru will result in the gland being too large to properly seal around the cable. I was hoping if I can take off the plastic connector housing the remaining cable assembly with the pins will be much thinner. My only other thought was to wrap a wad of electrical tape around the wire at the point it will pass thru the cable gland to increase the diameter of the cable at that point to make a good water-resistant seal inside the cable gland.
Old 11-11-2022, 08:13 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,678 Likes on 1,356 Posts
Is that connector open in the back where the wires come out? If it is, I would imagine you need a special tool to slip over the pins from the front to release them as you pull on the wire from the back. I am referring to the "front" as the red arrow side in the picture above.
Old 11-12-2022, 05:01 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
I've had considerable "luck" disassembling and re-pinning OEM connectors but cannot see any detail on this one so can't be too helpful. If the attached cable is just a two conductor without shielding it could be cut along its length, fitted through the cable gland and spliced back together somewhere along its run.
OR maybe looking into one of these handy devices: Cable Clam Blue Sea does have dimensioned drawings available for these devices.
Hope this helps!
Midnite150
2017+ Super Duty
11-23-2020 10:41 AM
CO Wapiti
2017+ Super Duty
05-30-2020 08:31 AM
jfmaz
1983 - 2012 Ranger & B-Series
01-18-2011 03:53 PM
NeuralMonk
05-07-2008 07:47 AM
Chance_Thomas
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-07-2006 11:08 PM
Quick Reply: How to dissemble/reassemble a modular connector.
